Members DwightT Posted October 12, 2023 Members Report Posted October 12, 2023 On 10/9/2023 at 5:15 AM, Gezzer said: don't know how long they will be a tight fit but I really think it will be quite a long time, I am sure one could make some sort of ledge inside ( silicone or hot glue or something ) when they are made to insure no problems I was thinking about this the other day. How about gluing or stitching a strip of leather to the inside to act as a ledge? Might have to do two layers to catch the candle depending on the slope of the sides, but it seems to me that would work. /dwight Quote
Members Wepster Posted October 12, 2023 Members Report Posted October 12, 2023 Depending on pattern, some small diameter brass rods run through would support the tea light, and provide an accent. Or decorative nails, or other embellishments to cover the wire or rods run through to support the tea light (or votive holder, depending on size). Or my idea of small block of wood sitting there, cheap, no work (or votive holder upside down, shot glass when not in use, 2 pieces of cardboard with lap joint (maybe not correct term) on edge, thread spool, or..... Quote
Members Gezzer Posted October 12, 2023 Author Members Report Posted October 12, 2023 @DwightT and @Wepster good ideas all around !! If the friction fit loosens over time a simple wrap of masking tape on the candle tin would work . I think it will take a small boat load of candles before it is a problem but I may be wrong . Quote
Members WalterF Posted October 29, 2023 Members Report Posted October 29, 2023 This is really nice, may try it if you don't mind. Quote
Members Handstitched Posted October 29, 2023 Members Report Posted October 29, 2023 I'm a bit late posting, but they are simple and practical , great Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Gezzer Posted October 29, 2023 Author Members Report Posted October 29, 2023 @WalterF Thank you and by all means make some .... but I'll need some pics @Handstitched Thank you Sir !!! Quote
Members Pinvazzy Posted March 19 Members Report Posted March 19 (edited) Using a candle holder in a leather project is a cool idea, and I think the snug fit issue can be solved by wet forming the leather around a mold slightly larger than the actual candle holder. That way, once it dries, it won’t be too tight. If dyeing after shaping, keep in mind that some finishes might stiffen the leather, making adjustments harder later on. Edited March 19 by Northmount removed spam link, you're walking on thin ice Quote
