Members maggielj Posted November 5, 2023 Members Report Posted November 5, 2023 I recently saw this while browsing, but it is a buckstitch needle for use in a cobra class 3 and 4. Has anyone used these? wondering if they’re worth the hassle. I would assume they could be used in other 441 clones Quote
Moderator bruce johnson Posted November 5, 2023 Moderator Report Posted November 5, 2023 Good reports on them. A shop by me kept an old Landis around that didn't sew, just had a wide needle and used it to punch holes for buckstitching. I think it was Shane Deeter who got these going for the closed eye needle machines. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members dikman Posted November 5, 2023 Members Report Posted November 5, 2023 Wouldn't it need it's own special feed dog? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Moderator Wizcrafts Posted November 5, 2023 Moderator Report Posted November 5, 2023 I wonder if a Union Lockstitch chisel awl can be fitted into the needle bar of a 441 clone? Mine are at the shop. I'll compare the length and shank diameter on Tuesday and report back. The needle bar can be adjusted up and down as needed. It just needs to take the awl shaft and lock it in. Then the awl can be angled for punching buckstitch holes. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
CowboyBob Posted November 6, 2023 Report Posted November 6, 2023 12 hours ago, Wizcrafts said: I wonder if a Union Lockstitch chisel awl can be fitted into the needle bar of a 441 clone? Mine are at the shop. I'll compare the length and shank diameter on Tuesday and report back. The needle bar can be adjusted up and down as needed. It just needs to take the awl shaft and lock it in. Then the awl can be angled for punching buckstitch holes. Why wouldn't a standard LR needle for a 441 work? Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Moderator Wizcrafts Posted November 6, 2023 Moderator Report Posted November 6, 2023 4 hours ago, CowboyBob said: Why wouldn't a standard LR needle for a 441 work? It might do if it is twisted so the chisel is at about 45 degrees. It would probably have to be a #26 needle. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members maggielj Posted November 7, 2023 Author Members Report Posted November 7, 2023 9 hours ago, Wizcrafts said: It might do if it is twisted so the chisel is at about 45 degrees. It would probably have to be a #26 needle. Perhaps I will just look into ordering some large sized needles and playing around with it. It may be more economical in the long run. Thank you all for the input. A chisel awl is something that may be hard for me to come across but I am curious to see the results. Thank you, maggielj On 11/5/2023 at 1:47 PM, bruce johnson said: Good reports on them. A shop by me kept an old Landis around that didn't sew, just had a wide needle and used it to punch holes for buckstitching. I think it was Shane Deeter who got these going for the closed eye needle machines. Thank you for the input! I will be trying this tool out and trying some large sized needles also. Thank you! maggielj Quote
Moderator Wizcrafts Posted November 7, 2023 Moderator Report Posted November 7, 2023 4 hours ago, maggielj said: Thank you all for the input. A chisel awl is something that may be hard for me to come across but I am curious to see the results. Campbell-Randall sells Union Lockstitch machines, needles, awls and accessories. @CowboyBob might have the leather point needles you need that are meant for your machine. You would need to angle the tapered points to get the buckstitch appearance. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Burkhardt Posted November 8, 2023 Members Report Posted November 8, 2023 On 11/6/2023 at 11:38 PM, Wizcrafts said: Campbell-Randall sells Union Lockstitch machines, needles, awls and accessories. @CowboyBob might have the leather point needles you need that are meant for your machine. You would need to angle the tapered points to get the buckstitch appearance. Would a sewing machine needle be as big as that in any size? I got a 441 and that looks huge. Quote
