  • CFM
13 hours ago, DwightT said:
FWIW: I've used Super Shene over Fiebings Pro Dye without noticing any problems.
Question for @chuck123wapati on the M&G or other floor wax products: any concerns with using an air brush to apply it?  The only thing I could think of would be that it might clog the nozzle but I would think that if I clean it thoroughly it would be OK.
    /dwight
Most air brush paints are acrylic based now a days i believe. I have used both super sheen and the acrylic mix in my airbrush with no problems as well as acrylic paints which again are a basic acrylic solution only with pigments added.. I go about 30 psi  As you say just clean real well.
Thanks.  I was just a little concerned because when I got this air brush it was totally clogged and I don't want to go through de-gunking it again.  It belonged to my wife's late husband and sat in the garage for many years and no clue what went through it then.
    /dwight
  • CFM
On 12/29/2023 at 10:00 AM, DieselTech said:
Yeah I dont have anything & it's too cold to ship.
So I was trying to come up with something to use.
I was going to suggest the M&G, but like Chuck, I remember the last time that came up.
I thought of it as well. Fortunately, this chap is a little better about considering a suggestion politely, without becoming snarky and insulting.
Lol you guys make me laugh. Just me thinking back when I read that thread. & how someone got soo bent out of shape.
  • CFM
so I'm dinking around today making this doodad and am trying to find a way to harden the tip a bit. I decided to try some of my floor wax ( pledge future) full strength i just used my finger and wiped it across the leather hoping to do a few good coats. It dried almost as fast as it was  applied with almost zero soaking into the leather. :huh: SO that is why it is diluted!!!! :Lighten: I tried another piece of scrap with a 50/50 mix to prove my theory lol. and yup the dilluted took longer to dry and so it soaked in about twice as far. Next test was with super sheen which I could tell is thinner and has much more water added than the 50/50 mix. The sheen soaked in about twice that of the 50/50 mix.  So an even more diluted mix would be better imo than 50/50 to get the sealer into the leather more efficiently.  Another thing I realize is if the first coat dries then your done anything else is only topical and could chip or peel. As before always test before using your leather may take it differently.
My doodad lol.
My doodad lol.
Thanks for the test & written info. I hear & seen a lot of good leather projects that were sealed with mop & glo type products.
I found out if you put super shene on too thick, & then let it dry, & try to bend/form your leather it will crack like safety glass.
I appreciate your feedback & scientific test.
Thanks.
Used it tonight, in a 50/50 dilution. I first used it on a belt that had a bleed through issue I couldn't nail down. Removed the rivets and dipped the entire thing a total of three times, drying in between. The only drawback was I had already used Resolene (tm), and the final result was fine "crackles" that can be felt but not visible. Pretty sure that's a case of over-application, but wanted to stop the bleed through
This time I used it on a vinegaroon dyed checkbook cover. I did the dip method again. Anticipated streaking, and had a section of sponge moistened in the solution and wiped it clear. When it dried sufficiently, noticed there was still light streaking, but it buffed out. Has I not been wanting to make sure the inside of the pockets were sealed, wouldn't have dipped it. This cover will be subject to sweat, and wanted to make sure everything is sealed.
