Members Brooks125 Posted February 19, 2024 Members Report Posted February 19, 2024 I was commissioned to make sponsor gifts for the local Ducks Unlimited Banquet. I was asked for suggestions and I came up with some of the usuals ... drink coasters or dresser valets with the DU logo stamped in. My contact suggested these shot gun holsters. In working up the prototype, I impressed even myself with 2 things: 1 - I picked the right material - 12/13 Bridle stock. No dying. No edging and it looks good. (The prototype has some VERY rough edges, but that was by design) 2 - It seems I got the pattern down on the first try, which is not typical for these odd projects. One note, they use a LOT of material and the design doesn't lend itself well to yield. I got 9 out of the first side of leather. The order is for 20 units! This should be fun, and I'm hoping will expand my product base a little, as well. Quote "Be polite. Be professional..."
Members MarshalWill Posted February 19, 2024 Members Report Posted February 19, 2024 Those look good. Are they designed to hold a box of shells? No edge beveling, no dying, just cut out and assemble. Nice design idea. Quote
Members DieselTech Posted February 19, 2024 Members Report Posted February 19, 2024 Looks good! So does item that hold a box of shotgun shells? Thanks. Quote
Members MarshalWill Posted February 19, 2024 Members Report Posted February 19, 2024 I don't see a logo on them anywhere. Will that get imprinted afterwards? Quote
Members Brooks125 Posted February 19, 2024 Author Members Report Posted February 19, 2024 No logo yet, still waiting on them to get the stamp. It holds the shotgun at your side. It's not particularly original, as I've seen them in the past and very early on, I tried to imitate them. This turned out much better. Quote "Be polite. Be professional..."
Members purplefox66 Posted February 19, 2024 Members Report Posted February 19, 2024 24 minutes ago, Brooks125 said: No logo yet, still waiting on them to get the stamp. It holds the shotgun at your side. It's not particularly original, as I've seen them in the past and very early on, I tried to imitate them. This turned out much better. That's a beautiful piece of wood on the shotgun what is the shotgun. Quote
Members TomE Posted February 19, 2024 Members Report Posted February 19, 2024 (edited) If I may suggest finishing and sealing the edges for outdoor use. This will help repel dirt and moisture to improve wear. I use mostly bridle leather for tack. It is a bit trickier to burnish than plain veg tan because the fibers are stuffed with fats and oils. You can get a fairly smooth edge by burnishing without sanding. My process is to bevel the edge then lightly wet it with water. I apply a small amount of saddle soap with a finger - just enough to feel it starting to get slick. Too much water or saddle soap will decrease the amount of dye absorbed in the subsequent step. I use a power burnishing wheel but canvas also works well to make the first pass. I then dye the edge with Pro dye or a 50:50 mix of Pro dye and Martin's Edge Solution. Once the dye soaks in I add a little saddle soap and burnish again. Gum tragacanth also works at this stage instead of saddle soap, but GT will seal the edge so you can't apply more dye if needed. Martin's Edge Solution creates a firm edge that is not sealed. I burnish before and after dyeing because it's easier to apply the edge dye evenly on a smooth edge. I usually finish by sealing the edge with beeswax applied with a heated edge iron. I let the wax harden for several hours before buffing with a soap cloth. This makes a serviceable edge for horse tack. I avoid acrylic finishes so the tack can be cleaned and conditioned as needed. Edited February 19, 2024 by TomE Quote
Contributing Member fredk Posted February 19, 2024 Contributing Member Report Posted February 19, 2024 That chap needs a heavier gauge belt. Its bending and twisting Quote Al speling misteaks aer all mi own werk..
Members Brooks125 Posted February 19, 2024 Author Members Report Posted February 19, 2024 1 hour ago, TomE said: If I may suggest finishing and sealing the edges for outdoor use. This will help repel dirt and moisture to improve wear. I use mostly bridle leather for tack. It is a bit trickier to burnish than plain veg tan because the fibers are stuffed with fats and oils. You can get a fairly smooth edge by burnishing without sanding. My process is to bevel the edge then lightly wet it with water. I apply a small amount of saddle soap with a finger - just enough to feel it starting to get slick. Too much water or saddle soap will decrease the amount of dye absorbed in the subsequent step. I use a power burnishing wheel but canvas also works well to make the first pass. I then dye the edge with Pro dye or a 50:50 mix of Pro dye and Martin's Edge Solution. Once the dye soaks in I add a little saddle soap and burnish again. Gum tragacanth also works at this stage instead of saddle soap, but GT will seal the edge so you can't apply more dye if needed. Martin's Edge Solution creates a firm edge that is not sealed. I burnish before and after dyeing because it's easier to apply the edge dye evenly on a smooth edge. I usually finish by sealing the edge with beeswax applied with a heated edge iron. I let the wax harden for several hours before buffing with a soap cloth. This makes a serviceable edge for horse tack. I avoid acrylic finishes so the tack can be cleaned and conditioned as needed. Thanks Tom. I will try that. It is good that I have plenty of scrap and the sanding did seem a bit "frayed". I'll try your version, or some close approximation - Thanks! 1 hour ago, fredk said: That chap needs a heavier gauge belt. Its bending and twisting No kidding. I'm often amazed at what some people will publish in their product shots. Quote "Be polite. Be professional..."
Members MarshalWill Posted February 19, 2024 Members Report Posted February 19, 2024 4 hours ago, Brooks125 said: No logo yet, still waiting on them to get the stamp. It holds the shotgun at your side. It's not particularly original, as I've seen them in the past and very early on, I tried to imitate them. This turned out much better. Well, that's certainly an interesting item. I haven't seen one before. But, I'm not in the duck crowd, either. Looking forward to seeing the final finished ones. Quote
