Members CKeebortz Posted February 20, 2024 Members Report Posted February 20, 2024 I need a machine for preferably around $200 for doing some stitching on 10-12 ounce leather straps. Im a firefighter and have always been into custom leather goods like Radio Straps and suspenders for my gear. Im starting to make my own and have been doing stitching by hand for a few now. With it being such long pieces even doing half at a time it takes forever. I need recommendations for a machine to do stitching on a 10-12 ounce strap for around $200 preferably cheaper is better. I thought about doing the cheap Chinese one on amazon but the stitching ive seen looks shotty and I want to keep high quality look. Right now Im using ritza tiger thread .8mm so i would need to use a thread that looks comparable to thickness when done. Thank you foe your suggesttions. Quote
Members DieselTech Posted February 21, 2024 Members Report Posted February 21, 2024 I dont think this is obtainable at $200. Quote
Members DieselTech Posted February 21, 2024 Members Report Posted February 21, 2024 If you get a amazon machine, like a shoe patcher or whatever it's called. Is going to take a bunch of hand finishing work to get it up & sew consistently & smoothly. The cheapest options I can think of is. Weaver 303 Cowboy 797 Sailite leatherworker/fabricator. Quote
kgg Posted February 21, 2024 Report Posted February 21, 2024 4 hours ago, CKeebortz said: I need a machine for preferably around $200 for doing some stitching on 10-12 ounce leather straps. In his day and age getting a machine for $200 that works and that can handle 10-12 oz leather is as scarce as hens teeth. The amazon machines, Chinese Patchers, I call them the "Tinkers Delight", which for most are going to be a waste of money but are great frustration generators. If you moved your budget up to the $1000 mark you could probably get a good used upholstery class machine depending on where you live or a new manual class 441 like a Tippmann Boss. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted February 21, 2024 Moderator Report Posted February 21, 2024 7 hours ago, CKeebortz said: I need a machine for preferably around $200 for doing some stitching on 10-12 ounce leather straps. You need to increase your budget. $1400 is about the bottom price for a new stitcher capable of sewing 12 ounces of veg-tan. Here is an example of a $1400 leather stitcher that comes with a servo motor and table. You may find some deals on used walking foot machines in your local Facebook Marketplace, or Craigslist. I see decent walking foot machines selling from $800 to $1200 all the time. They are basically upholstery sewing machines, with triple feed. Many can sew up to 3/8 inch of soft to medium temper materials, and about 1/4 inch of hard temper belt leather. These machines would max out with #138 bonded thread, which has 22 pounds breaking strength. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members GerryR Posted February 21, 2024 Members Report Posted February 21, 2024 (edited) I have a "Chinese Patcher" and put a servo motor/controller on it. It cost me about $150.00 total. Maybe I'm not as fussy as others, but I think the stitching is fine. I changed the needle system to 135x16 so I have more options, and can sew up to 138 thread size. The change was rather minor; the needle bar had to be adjusted. I have a way of putting a flat on the needles like the HAx1 that the standard machine uses, but I have read where others modify the groove in the needle bar to accept the round 135x16 needles. The real negative I find to be is the small bobbin size, but I have been able to do the complete perimeter of a belt with no problems. Still the best buy to get one into a machine! (I had a Singer 153W103 and sold it as this sewed just as well. YMMV!) It will do up to 5/16" (20 oz.) leather, depending of course on the temper. Edited February 21, 2024 by GerryR Quote
Members jollyroger Posted February 21, 2024 Members Report Posted February 21, 2024 6 hours ago, GerryR said: I have a "Chinese Patcher" and put a servo motor/controller on it. It cost me about $150.00 total. Maybe I'm not as fussy as others, but I think the stitching is fine. I changed the needle system to 135x16 so I have more options, and can sew up to 138 thread size. The change was rather minor; the needle bar had to be adjusted. I have a way of putting a flat on the needles like the HAx1 that the standard machine uses, but I have read where others modify the groove in the needle bar to accept the round 135x16 needles. The real negative I find to be is the small bobbin size, but I have been able to do the complete perimeter of a belt with no problems. Still the best buy to get one into a machine! (I had a Singer 153W103 and sold it as this sewed just as well. YMMV!) It will do up to 5/16" (20 oz.) leather, depending of course on the temper. I would be interested in more details about your Chinese Patcher so I can try to replicate it. The Cowboy CB2500 looks pretty nice but I don't have $1500 for a machine yet - hopefully one day. thanks for your input Quote
Members purplefox66 Posted February 22, 2024 Members Report Posted February 22, 2024 You are way way better to not gat any machine until you find one that meets your needs. Save your money until you can buy what you need and not just any sewing machine. Quote
Members jollyroger Posted February 22, 2024 Members Report Posted February 22, 2024 2 minutes ago, purplefox66 said: You are way way better to not gat any machine until you find one that meets your needs. Save your money until you can buy what you need and not just any sewing machine. good advice. my first need is to stitch faster and it sounds like it meets GerryR's needs. And I won't really know what my needs are until I get a machine that can't meet them, right? seems like a cheaper, capable machine is the best one to learn on but I'm new here and don't really know. Quote
Members purplefox66 Posted February 22, 2024 Members Report Posted February 22, 2024 The best machine to learn on is the one that meets your needs Quote
