39 minutes ago, bladegrinder said:
Nice! When I got my CB4500 I was a little nervous, never ran a sewing machine. Now I sit right down and get er done. I can count my time doing a knife sheath on it in seconds and holsters in a few minutes, and that’s just feathering the go pedal at a crawl. I’m really liking that machine.
Yeah I was going to get a cowboy cb4500, but the shipping was going to be twice as much than the cobra. So I went that route.
I cant wait to use it. Lol I might get it put together tonight.
  • Replies 113
  • Created
  • Last Reply
Top Posters In This Topic
Remember what I said about the motor brake, if yours has it. I took the brake pad out of mine, you had to push the go pedal to turn the flywheel, I didn’t like that.
Now I remember it. But I dont remember where the actual brake is. & how you disable it or back it off.
Thanks.
On mine I took the cover off the back of the motor, you can see the pedal linkage connected to it. It looks like a car brake of just tiny.
Guys & gals my EPS directions got accidentally taped on the inside of the box & destroyed them when I opened the box.
Does my EPS look like everything is installed right? The red Mark's were there from leather machine co. So I just lined them up.
Does this look correct?
Thanks.
Edited by DieselTech
Looks good to me. If not quite right just turn those discs.
Yeah I finally found a video by Van Plew on youtube about cobra class 4 eps installation.
On another note I got a thread in thread guide I'm not sure as to where it goes. I found 1 spot right on top it threads into. Lmao I just dont know if it goes there.
I cant find anything about it.
Makes no sense. Pictures?
Well I modified my flatbed attachment for Patrick1 flat extreme needle plates. It turned out good.
Only thing required to modify it to fit the needle plates, was to mark the corners around the needle plate & file the table attachment in the corners around the needle plate.
On 3/13/2024 at 10:31 PM, bladegrinder said:
Yea, I had quite the pile of sewed up scrap. the one thing I kept doing was I'd end on one piece of scrap in reverse then when I started another one I forgot to switch to forward, but now stitching knife sheaths or holsters I always start in reverse and end in reverse.
I also find myself hand turning the flywheel by hand at tight spots or turns, taking the brake pad out of the motor helps with that a lot, with the brake pad in, you have to push the pedal a small amount to free the flywheel, so there's lag in the machine starting. the way I have my pedal set up now there's no play before the machine starts running, you touch it and it goes.
Where is the brake pad in the moter located? I didn’t know they had brake pads in them!
