CFM chuck123wapati Posted May 7, 2024 CFM Report Posted May 7, 2024 1 hour ago, JLDetroit said: Sometimes when setting double cap rivets, the leather is pushing back, so I inserted a rivet setter into a file handle. Then I can use the tool to push the rivet down until the cap clicks in place before I use another rivet setter to actually set the rivet. Awesome idea! a guy could set that in a handle you could whack with a mallet then you wouldn't need two. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
toxo Posted May 10, 2024 Author Report Posted May 10, 2024 I think I've posted this before but I have to do it again under this banner of making things easier. I debated whether to post it in the beveller post but I think it's way more than just a burnisher. In this video I've replaced one of the belts with felt. It was a half-arsed effort but done properly I think it would be awesome. Note that this is real time with just water as against spending hours at it. The green compound is'nt right for this but this awesome for stropping blades. Please bear in mind I'm no videographer. Quote
Members dikman Posted May 10, 2024 Members Report Posted May 10, 2024 I've never seen one of those machines before. I like it! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
toxo Posted May 10, 2024 Author Report Posted May 10, 2024 (edited) 37 minutes ago, dikman said: I've never seen one of those machines before. I like it! I've seen a couple of different combinations lately. I'll see if I can find em. Here ya go; Scheppach BGS700 150mm Brushless Electric Grinder / Linisher 230V - Screwfix Electric Belt Sanding Machine, Mini Belt Sander Electric Knife Edge Sharpener Sanding Machine Belts Adapter Polisher Kits Mini Bench Grinder 7 Adjustable Speed (UK 3 Pin Plug Upgrade) : Amazon.co.uk: DIY & Tools BUCKTOOL 500W Bench Belt Sander 4 in x 36 in Belt and 6 in Disc Sander with Direct-Drive Motor, BD4603 : Amazon.co.uk: DIY & Tools JEEVOO Mini Belt Sander - Electric Double-Ended Bench Belt Grinder Kit for DIY Woodworking, Metal, Knife Making : Amazon.co.uk: DIY & Tools Edited May 10, 2024 by toxo Quote
Contributing Member fredk Posted May 11, 2024 Contributing Member Report Posted May 11, 2024 More from me Forget your poundo board or pieces of scrap leather; make yourself a big wax block. When stitching chisels go though the leather and into the wax they automatically get 'lubed'. After a session some heat will melt the wax and give a good surface for the next time And to help pull those chisels out of the leather and to mark the stitching line I'd be lost without my Tandy pens - I have many of them I have several lead weights, for use when gluing up large areas, holding large pieces of leather on the cutting table whilst measuring up and cutting. . . . I really must do something with them. I have a couple of 1 kg barbell weights as well and my TandyPro Press. I'd be scunnered without it. Used for die cutting, 3D stamping et cetera. I keep the supplied base plate off and use some pieces of delrin or nylon . . . . Quote Al speling misteaks aer all mi own werk..
Members dikman Posted May 11, 2024 Members Report Posted May 11, 2024 I found the same machine, Toxo, $120 on sale which is pretty good BUT the belts are an odd size and I could only find one seller on Aliexpress. So not such a good deal...... Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
toxo Posted May 11, 2024 Author Report Posted May 11, 2024 3 minutes ago, dikman said: I found the same machine, Toxo, $120 on sale which is pretty good BUT the belts are an odd size and I could only find one seller on Aliexpress. So not such a good deal...... I don't remember paying anything like that price. Maybe my belts are thinner? Quote
toxo Posted May 11, 2024 Author Report Posted May 11, 2024 3 hours ago, dikman said: I found the same machine, Toxo, $120 on sale which is pretty good BUT the belts are an odd size and I could only find one seller on Aliexpress. So not such a good deal...... Don't remember having trouble finding the belts but I also have a box of these that I can make belts from. LYFJXX Emery Cloth Roll, 6 Grits Abrasive Sand Paper Roll for Woodworking, 80 150 240 320 400 600 Grit Sandpaper for Metal, Each Roll 8 Meters : Amazon.co.uk: DIY & Tools Quote
Members dikman Posted May 11, 2024 Members Report Posted May 11, 2024 16 hours ago, toxo said: I don't remember paying anything like that price. Maybe my belts are thinner? Inflation, my friend! It still intrigues me, being variable speed and portable. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members TomWilson Posted May 21, 2024 Members Report Posted May 21, 2024 A helpful clamp design. Quote
