Hello, I was wondering if anyone had any advice about where I could find rivets (or better yet, Chicago screws) with attached swivel rings with diameters of 3/4" or more, preferably in a bright brass color. I'd also appreciate any feedback on if this hardware would be durable, or if it would degrade/stress the leather it is attached to.
I've attached a visual example of what sort of hardware I am after.
 Example of smaller ringed chicago screw
Might consider a swivel with 2 rings or squares. More to choose from at Weaver, Buckle Guy, Batz Corp, Bieler's Manufacturing.  Could attach one ring to the project with a leather chape or loop. Stohlman shows examples for attaching buckles and rings in volume 1 of his case making books.
15 hours ago, suedorade said:
Hello, I was wondering if anyone had any advice about where. . .  I'd also appreciate any feedback on if this hardware would be durable, or if it would degrade/stress the leather it is attached to.
They don't degrade the leather or do it any harm. But they're not suitable for heavy use, only for the likes of a wrist-strap on a purse
I use these and I find I have to replace the screw with a longer one and use a plastic washer under the screw
Had to dig but I knew I had some of these somewhere  but can't remember where from. If you don't have any joy, come back and I'll find em.
These would be perfect! I would love to know where you got them, especially those that I've circled below:
I had mine custom made , the o ring is about 1.5in  and they are screw back . I used them exclusively for dog collars . Anyone with a machine shop can make them for you
No photo description available.
Edited by LeatherLegion
This is my use for them as well haha. Could I ask what the price point of that was for you? I'm not looking to go into mass production so I'd be buying less than 15 of them, which may get expensive with a custom order.
I'll try to find them.
Haven't found them but narrowed it down to almost certainly,
www.londontrimmings.co.uk
Amazing place.
Amazing place.
Well I couldn't find them there, but thank you for introducing me to this site! They sell lots of materials for other hobbies of mine :)
Last batch  i had made was 10-12 years ago...They were about $40/piece
You're very welcome. Just wish I could take you to  JT Batchelors in London. An old Victorian mews building that sells all the normal stuff, leather,  tools,  hardware etc but also with narrow aisles with dusty boxes full of inspiration that haven't been seen for years.
  • 6 months later...
You may be able to find the rivets or Chicago screws with the attached swivel rings through online search of hardware suppliers or leatherworking stores which have specialized appliances. Websites like Tandy Leather, Weaver Leather, and even bigger platforms such as Amazon and eBay may have the particular products in the colors you want to be them bright brass or another one. Nevertheless, it is important to be aware that the screws and rings are made of high-quality materials, such as solid brass, to make them last longer and to prevent corrosion. Moving on to the durability factor, Chicago screws with swivel rings have the desired tenacity for leather projects in common cases, nonetheless, in a longer run, the stress or weight may cause the problems overclock, especially in case the leather is not maintained in a proper way or if it is subjected to the heavy-use projects. However, use the correct size screws for the leather thickness to avoid damaging it by stretching it out too much or breaking it.
