Members MB1 Posted November 13, 2024 Members Report Posted November 13, 2024 (edited) Hi everyone! I'm new here and new to the leather world I want to know if there's any website or youtube channel that can help me starting out. Also I wanted to ask how I can create this type of lead, without stitches holding the clipper and with a secondary color added Thank you in advance! Edited November 14, 2024 by Northmount Replaced webp file Quote
Northmount Posted November 14, 2024 Report Posted November 14, 2024 22 hours ago, MB1 said: Also I wanted to ask how I can create this type of lead, without stitches holding the clipper and with a secondary color added bleed knot, blood knot, slit braid are all terms relating to this braid. I have seen the 2 colour braid somewhere but can't locate it at the moment. Moved your post to Specialty Leatherwork > Other Specialties > Collars, Cuffs, Leashes and Leads Converted and replaced your webp photo file. Many members will not download and open file types they are not familiar with. Use jpeg or png files as they will display without having to download them. Webp files are from google and chrome. Google owns the world! You can do a google search limited to leatherworker.net like this: site:leatherworker.net "your search parameters". replace the "your search parameters" with the words / items you are searching for (without quotation marks). example: site:leatherworker.net bleed knot Quote
Members DieselTech Posted November 14, 2024 Members Report Posted November 14, 2024 (edited) 23 hours ago, MB1 said: Hi everyone! I'm new here and new to the leather world I want to know if there's any website or youtube channel that can help me starting out. Also I wanted to ask how I can create this type of lead, without stitches holding the clipper and with a secondary color added Thank you in advance! The bowtie loops can be made with a leather cutting die. Or as Northmount mentioned a bleed knot can be made. Here is a pic of the cutter die. They make a larger die for handbags & such, but wanted to show you the die shape. Edited November 14, 2024 by DieselTech Quote
Members DieselTech Posted November 14, 2024 Members Report Posted November 14, 2024 Here is the large bowtie leather cutting die. Quote
Northmount Posted November 15, 2024 Report Posted November 15, 2024 @MB1 I've done some more searching. The correct name for the 'braid' is called a slit braid. See Bruce Grant's Encyclopedia of Rawhide and Leather Braiding. Many people call it a bleed knot or blood knot. To get the secondary colour, locate the position the clip will be placed and dye the short end red or your selected colour. Then proceed with your "braiding". Quote
Members MB1 Posted November 15, 2024 Author Members Report Posted November 15, 2024 10 hours ago, Northmount said: @MB1 I've done some more searching. The correct name for the 'braid' is called a slit braid. See Bruce Grant's Encyclopedia of Rawhide and Leather Braiding. Many people call it a bleed knot or blood knot. To get the secondary colour, locate the position the clip will be placed and dye the short end red or your selected colour. Then proceed with your "braiding". Thank you so much. I have a lot to learn and very motivated to, the "problem" is finding the right tools to learn what I want to do Quote
AlZilla Posted November 15, 2024 Report Posted November 15, 2024 (edited) 1 hour ago, MB1 said: the "problem" is finding the right tools to learn what I want to do Don't get hung up needing all the name brand, hi dollar tools everyone seems to have. Get a basic tooling set and get to work. Looks like an Exacto knife and a straight edge are all you need for those dog leads, Pretty cool looking, actually. Edited November 15, 2024 by AlZilla Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
kgg Posted November 15, 2024 Report Posted November 15, 2024 (edited) 3 hours ago, MB1 said: I have a lot to learn and very motivated to, the "problem" is finding the right tools to learn what I want to do I agree with @AlZilla thoughts on tools. This type of dog lead looks really pretty but from my experience it should not be used on trying to control a larger or more powerful dog. Also be careful in choosing the correct weight and width of leather. I find using two layers of 6 or so ounce leather glued together gives a nice smooth surface on both sides. I also stitch both edges the length with V138. I figure this would be good up to about an 80lb dog. Also use #9 copper rivets at the clip end and for connecting the loop to the lead. If you need to make one for a real puller I would suggest incorporating a nylon webbing between the two layers of leather. Just my thoughts. kgg Edited November 15, 2024 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
1hp Posted November 15, 2024 Report Posted November 15, 2024 @brucejohnson sells bleed knot tool. Quote
Members MB1 Posted November 20, 2024 Author Members Report Posted November 20, 2024 On 11/15/2024 at 12:02 AM, Northmount said: @MB1 I've done some more searching. The correct name for the 'braid' is called a slit braid. See Bruce Grant's Encyclopedia of Rawhide and Leather Braiding. Many people call it a bleed knot or blood knot. To get the secondary colour, locate the position the clip will be placed and dye the short end red or your selected colour. Then proceed with your "braiding". It's actually another leather strip added and not dyed. I think they maybe end the initial strip after the first knot around the snap hook and then add the secondary strip? Quote
