Members Chris777 Posted 14 hours ago Members Report Posted 14 hours ago I’m working on my first project, which is a simple bookmark. I’m using 4/6 veg tan leather. The issue is with the dyeing. The first image (lighter color) was done using a wool dauber. It’s uneven because I had to go over some areas that didn’t get into the stamping. The darker one was an attempt at submersing in the dye and it looks horrible and worse, it’s really stiff. Do you have any suggestions, I’m really disappointed. Quote
Members DieselTech Posted 13 hours ago Members Report Posted 13 hours ago How long has the bottom example been drying? If I dip using fiebings pro dye, it takes a good 12hours, sometimes more to fully dry out. I've had no luck using a dauber. I dip dye if I can. Quote
Members DieselTech Posted 13 hours ago Members Report Posted 13 hours ago Also another thing I forgot to mention, sometimes it's the leather quality/brand that can have uneven dying/splotchiness. I had a really nice looking imported veg-tan that did that to me in 1 part of the side I bought. Quote
Members JDFred Posted 2 hours ago Members Report Posted 2 hours ago (edited) Sometimes it takes over night for the dye to finish moving through the leather. Oiling it after you dye it also helps the dye to even out , also let the oil sit over night before you judge it. I use Angelus alcohol based dyes and apply with a wool dauber. Do you apply the dye in lines or in random circles? I’ve had better luck getting down into things and mor even coverage using circles. Leather quality dose make a difference also. I’m not to the point where I think I’m ready to buy good leather yet so I get some of those spot that don’t take dye real well it’s part of it. Just keep after it and it will get better. Edited 2 hours ago by JDFred Quote
Members Chris777 Posted 1 hour ago Author Members Report Posted 1 hour ago Thanks for the feedback. The darker one has been sitting for a week, the other one longer. It’s not a top quality leather. Quote
Members Beehive Posted 45 minutes ago Members Report Posted 45 minutes ago Did you oil it before applying the dye? Like giving it a rub with neatsfoot. Letting it set over night until you don't see blotches of oil. To where it looks just like it did, before you started. Just a tiny bit darker? I find oiling the leather before dying evens out the dye. It's my standard practice when using alcohol based dye. Oil based already has the oil in it. Quote
Members BlackDragon Posted 24 minutes ago Members Report Posted 24 minutes ago Make sure your leather is completely dry after tooling. My steps for dying. 1. Neatsfoot oil. You don't need a lot. It'll help distribute the dye evenly in the next step. Let sit for at least 12hr. 2. Apply dye, usually I use a sock or you can use a wool pad. Let it sit for min 12hrs. I avoid dabbers unless I can cover the piece in one or two swipes, like a bracelet or belt loop. Before going on to the next step make sure your project is dry. 3. The leather will be stiff after dyeing so work it a little. Gently bending it around, this allows the pores to open up and makes it more supple. It also lets your waxes or resolene get better penetration in the next step. 4. Apply either resolene or wax depending on the project or preference. Quote
