Members 1Poet Posted April 2, 2025 Members Report Posted April 2, 2025 I have not been this exact problem discussed. If it has I apologize. I cannot get the upper tension correct on my cb4500. I have made positively sure that it is properly threaded with 207 thread. Proper 23 needle. I test on two pieces 7/8 veg tan. No matter where I set the tension, primary and secondary, the thread does not consistently place the tread into the leather, as designed. A few stitches will be ok and then several at the top of the stitch row. I have checked the entire tension springs and parts. All ok. I have the tension screw adjusted almost off the post and it still is not pulling the thread inside, or below the surface. I know I must be missing something but I don't know what! I am not a newbie. Been sewing many, many years, but not on this type HD machine. Any help will be heartily appreciated! Thanks in advance! Quote
Northmount Posted April 2, 2025 Report Posted April 2, 2025 59 minutes ago, 1Poet said: I have checked the entire tension springs and parts. All ok. I have the tension screw adjusted almost off the post and it still is not pulling the thread inside, or below the surface. Which thread, top or bottom? Pictures of the top and bottom stitches would help. Quote
Members 1Poet Posted April 3, 2025 Author Members Report Posted April 3, 2025 (edited) Will take pics and post asap. However, it is the top thread tand is pulling up to the leather surface. Edited April 3, 2025 by 1Poet Quote
Moderator Wizcrafts Posted April 3, 2025 Moderator Report Posted April 3, 2025 2 hours ago, 1Poet said: I cannot get the upper tension correct on my cb4500. I have made positively sure that it is properly threaded with 207 thread. Proper 23 needle. Will take pics and post asap. However, it is the top thread and is pulling up to the leather surface. Most of us use a #24 needle with #207 thread, top and bottom. However, if you use #138 in the bobbin, a #23 needle should work. If the knots are showing on top, and you've backed off the top tension settings (primary and secondary disks), Increase the bobbin spring tension. Also, install the bobbin so that it feeds against the direction of the slit to the spring. This increases the tension while ensuring that the thread doesn't work itself out of the tension spring. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members shoepatcher Posted April 3, 2025 Members Report Posted April 3, 2025 21 hours ago, Northmount said: Which thread, top or bottom? Pictures of the top and bottom stitches would help. go to a #24 NEEDLE. hole made by #23 is not big enough for the thread to come up thru the hole. glenn Quote
Members amuckart Posted April 3, 2025 Members Report Posted April 3, 2025 Watch how the thread is coming off the spool as you sew. If it’s not despooling cleanly and catches at certain positions that’ll cause a tension spike in the top thread. The solution if it’s just catching at a certain point is to make sure the thread guides are exactly centred over the spool and to make sure there’s enough distance between the top of the spool and the thread guides. if the thread is catching because the bottom of the spool has rolled or collapsed a bit I don’t know how to solve that. Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
Members 1Poet Posted April 17, 2025 Author Members Report Posted April 17, 2025 Thanks for the input! Wizcrafts, are you saying to change the normal way the spool is inserted into the bobbin? I am a little unclear on that. Quote
CowboyBob Posted April 17, 2025 Report Posted April 17, 2025 If your bobbin thread is showing on top it has nothing with the #23 needles,we have people using that size all the time.I would suspect you need to tighten your bobbincase tension spring to get it to pull down.If that doesn't work you should get a new bobbincase spring. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Moderator Wizcrafts Posted April 17, 2025 Moderator Report Posted April 17, 2025 9 hours ago, 1Poet said: Thanks for the input! Wizcrafts, are you saying to change the normal way the spool is inserted into the bobbin? I am a little unclear on that. Yes. I tend to load all of my bobbins so that they feed into the bobbin spring slot at a right angle. This keeps the thread firmly seated under the spring and slightly increases the bobbin thread tension. It isn't gospel, but helpful with some thread that might be twisty. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
