Members Carlsen Carlsen Posted June 16 Members Report Posted June 16 Thanks for let me in, i'm new in this world Dear All Toyota fans I need a little help Q: What are these 2 "button for the green and red arrow are pointing at? And how can i freewind so i can only run whit pulleys so I can fill up my bobins or if someone have a manual i can get will i be grateful Thx in advance Quote
kgg Posted June 16 Report Posted June 16 1 hour ago, Carlsen Carlsen said: What are these 2 "button for the green and red arrow are pointing at? The green arrow points to what looks like a oiling port for the internal parts similar to the Juki LU-562 & 563. The red arrow points to the stitch length adjuster as I don't see a stitch length adjusting dial or it is a safety clutch to protect the hook assembly when you jam up the machine. 1 hour ago, Carlsen Carlsen said: And how can i freewind so i can only run whit pulleys so I can fill up my bobins If you want to wind just a bobbin: Here is a link to pretty good video from the 9:00 minute mark ( i) remove thread from needle otherwise you will jam the machine up. ii) the winder needs to be set so it trips out when you get about 80 percent of the bobbin filled. iii) install empty bobbin on winder shaft. Most bobbins have holes on the sides of the bobbin so a) the end of the thread from the spool of thread you are using to fill the bobbin through the winders tension discs then to the inside of the bobbin outwards through a hole b) push the bobbin trip lever towards the rear of the machine to engage the winders drive wheel up against the machines drive belt c) hold the end of the thread in your hand d) hit the go pedal e) hold the end of the thread until you have at least two complete rows wound on the bobbin. iv) you really should have two spools of thread one for the top thread and one for the bobbin thread so you don't have to unthread the machine just to wind a bobbin. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Carlsen Carlsen Posted June 16 Author Members Report Posted June 16 Dear KGG Thanks for Your reply pls look at my photo below, this "onewaywheel" blue arrow can be activated by pressing the "red arrows" it's a rubber bottom, and here is what it's look below Reverse, 2'nd photo in the lever that the yellow arrow are pointing at, it go reverse by pushing it down, and stitching length are adjusting by a shiny nut in the lever,, I hope it make any sense 🙂 Quote
Northmount Posted June 16 Report Posted June 16 6 hours ago, Carlsen Carlsen said: I need a little help I moved your post to Leather Sewing Machines. This is where the machine guys hang out. Secondly, your photos are too small to see details. Resize photos (JPG or PNG) to 800 pixels in the longest dimension. That will produce files with enough detail and still meet the size restrictions on this site. Quote
Members Carlsen Carlsen Posted Tuesday at 07:54 AM Author Members Report Posted Tuesday at 07:54 AM On 6/16/2025 at 6:54 PM, Northmount said: I moved your post to Leather Sewing Machines. This is where the machine guys hang out. Secondly, your photos are too small to see details. Resize photos (JPG or PNG) to 800 pixels in the longest dimension. That will produce files with enough detail and still meet the size restrictions on this site. Thanks for your help I will remember that including photo size Quote
Members Sheilajeanne Posted Wednesday at 03:02 PM Members Report Posted Wednesday at 03:02 PM Toyota makes SEWING Machines?? Ya learn something new every day! [Pats the hood of her Rav4] Here's hoping they're as reliable and well-built as their cars are! Quote
Moderator Wizcrafts Posted Thursday at 02:03 AM Moderator Report Posted Thursday at 02:03 AM 10 hours ago, Sheilajeanne said: Toyota makes SEWING Machines?? Ya learn something new every day! [Pats the hood of her Rav4] Here's hoping they're as reliable and well-built as their cars are! I think they can go 10,000 miles, er stitches between oil changes! ;-) Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Sheilajeanne Posted 23 hours ago Members Report Posted 23 hours ago LOL, Wiz! I recently traded in my 2010 Rav4 with 230,000 km. on it for a newer one. The only problem I had that wouldn't qualify as routine maintenance was a front ball joint needed replacing. Oh, and I managed to rip the bumper off one day by catching it on the tire of a parked truck... The truck was totally unharmed, fortunately. Quote
CowboyBob Posted 16 hours ago Report Posted 16 hours ago On 7/23/2025 at 10:03 PM, Wizcrafts said: I think they can go 10,000 miles, er stitches between oil changes! 😉 That's what the factory recommends BUT if you do it the rings might get gunked up with carbon & start using alot of oil. Then you'll have to look for a video on Youtube on how to repair it. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
