These were fun. Hope you like em.
yup, I like them, A bit of class
They both are really awesome! Very nice work.
Thanks. The caiman is a bear to work with. The snapping turtle was far simpler.
Thanks. Fun builds. I Definitely like the snapping turtle and need to get some more of that haha
Nicely done!  I have some caiman but the holster design I was looking to use it on has proven to be difficult without very thin borders on the window (an avenger style).
Did you back the caiman in the window of the outer later Or, did you use three layers. Outside, lining with Caiman, backside?
DAve
nice look!
  • CFM
Those Rock!!!! you need my address?
Did you back the caima7u8⁷n in the window of the outer later Or, did you use three layers. Outside, lining with Caiman, backside?
DAve
I had used multiple layers. Both of these were made from laminated 4-5 oz leather to make  the front and back panels.
The front panel requires additional work obviously. I cut the window out,  trimmed and skived the plug, skived the areas of the panel from the stitch lines to the edges, glued the plug in place, glued the caiman over the plug, then glued the window over everything and stitched it together.
On 7/14/2025 at 8:20 AM, DoogMeister said:
nice look!
Thanks
Sure! Postage may be expensive though ;) haha
4 hours ago, PastorBob said:
Nice work!!
Thanks!
