Members Shadders Posted August 12 Members Report Posted August 12 Hello, After taking a rather long and unintended break away from leathercraft, I've returned to it, and completed a couple of basic wallets as my first couple of baby steps projects. I used Walpier museum buttero for the first and Badalassi carlo pueblo for the second. For the latter, I lined the note holder with napper lamb. I found the napper to be more challenging to cut correctly due to it's stretchines. Now, I've purchased some goat from Tusting & Burnett. I find that the goat has similar qualities when it comes to cutting it accurately. The line is not straight, even though I'm cutting against a cork backed steel rule. I don't think my blade is a problem, it's stropped enough for a good polish and shaves arm hair easily. I think the ruler could be a problem, the cork side is not flush with the rule, stopping ~1mm from the steal edge. I also feel my technique could be better, maybe inconsistent pleasure and/or angle. If there's anyone out there who'd like to share how they cut the more flexible hides, I'd love to learn from their experience please. Best regards, Shadders Quote
Contributing Member fredk Posted August 12 Contributing Member Report Posted August 12 Heavy weights to hold down and a very sharp rotary knife. I use a 60mm diameter blade rotary knife Quote Al speling misteaks aer all mi own werk..
Members dikman Posted August 12 Members Report Posted August 12 Yep, I've found one of those rotary cutters much better on softer material because there's no drag like you get pulling a blade. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Shadders Posted August 15 Author Members Report Posted August 15 Hello All, Just wated to say thank you for your advice. I got my rotary cutter yesterday and it's made a big difference. Best regards to you all. Quote
Members sportycliff Posted 1 hour ago Members Report Posted 1 hour ago Instead of cork backing, try using 220-400 grit adhesive backed sandpaper on your rules. Right to the edge, as long as you're slightly careful it shouldn't scratch the leather, and it will minimize stretch. I like the rotary cutters as well, but it's another tool to keep sharp. Just another option... Quote
CFM chuck123wapati Posted 1 hour ago CFM Report Posted 1 hour ago I use scissors. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
