Members SR71 Posted September 25 Members Report Posted September 25 Hi everyone, I am looking for this specific hardware to tether a chain to a trucker wallet. Anyone know any good sites for this type of hardware? Ideally in both solid brass and nickel options. Many thanks! Quote
Members Dwight Posted September 25 Members Report Posted September 25 Ohio Travel Bag is a name you may look at . . . I believe they are owned by Weaver Leather now May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
CFM chuck123wapati Posted September 25 CFM Report Posted September 25 2 hours ago, SR71 said: Hi everyone, I am looking for this specific hardware to tether a chain to a trucker wallet. Anyone know any good sites for this type of hardware? Ideally in both solid brass and nickel options. Many thanks! you could make that in less time than it took you post this. Am I missing something? Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members SR71 Posted September 25 Author Members Report Posted September 25 33 minutes ago, chuck123wapati said: you could make that in less time than it took you post this. Am I missing something? Hi there, thanks for answering! I’m just wondering where I could source this hardware? Also if you could provide the names of these pieces that great. I know one part is called an eyelet/gromet, but not sure what the long, oval ring would be formally named? Any help is appreciated. Kind regards. Quote
Members BlackDragon Posted September 25 Members Report Posted September 25 These are two separate items; a grommet and a brass chain link. The grommets you can find pretty easily. The individual brass links are going to be harder to source. You can buy a brass chandelier chain and take off links as you need them. Make sure you get a good thickness so it doesn't pull apart. Quote
Members DocReaper Posted September 25 Members Report Posted September 25 I wanna know how Chuck123 would make it! Quote Doc Reaper
Contributing Member fredk Posted September 25 Contributing Member Report Posted September 25 Even I could make it. Anneal some brass rod, bend either free-hand or round a former then heat & squench Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted September 25 CFM Report Posted September 25 13 minutes ago, fredk said: Even I could make it. Anneal some brass rod, bend either free-hand or round a former then heat & squench there ya go!! Then I would coil a whole stick of it around a piece of hardwood or steel after annealing, then cut it down the side making dozens at once. Like they make chain mail. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
AlZilla Posted September 25 Report Posted September 25 You can see on the bottom center that it's not joined in any way. Just bent into place. Easy to duplicate since it doesn't need or have any strength. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Contributing Member fredk Posted September 25 Contributing Member Report Posted September 25 6 minutes ago, AlZilla said: You can see on the bottom center that it's not joined in any way. you could solder/braze or whatever to join it and make it more secure Quote Al speling misteaks aer all mi own werk..
