Members Jacqui Posted October 8 Members Report Posted October 8 So I've never worked with leather before but have made bags for around four years with vinyl. My leather bundle has arrived today and my new skiving machine is due with me in two days. It is a Krafft 801. Any tips etc on how to use it for a newbie. Tips, tricks etc - stumbling blocks to try to avoid. Thanks all Quote
AlZilla Posted October 8 Report Posted October 8 Let's try this over here in Leather Machinery, @Jacqui. It seems to be the place for skivers. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
toxo Posted October 8 Report Posted October 8 1 hour ago, Jacqui said: So I've never worked with leather before but have made bags for around four years with vinyl. My leather bundle has arrived today and my new skiving machine is due with me in two days. It is a Krafft 801. Any tips etc on how to use it for a newbie. Tips, tricks etc - stumbling blocks to try to avoid. Thanks all Welcome Jacqui and congratulations on getting an 801 skiver. It's an amazing piece of kit but be prepared to waste a lot of scrap learning how to use it properly. It might be a strange thing to say but I enjoyed that learning process immensely. You'll learn about different types of feed roller/presser feet/what speed to use and how things change when switching to a different thickness of material. When you think you've got it right it might not work as good on a different TYPE of leather/vinyl so the most important piece of advice I can give you is ALWAYS ALWAYS get it perfect on scrap before putting hours of work through it. Good luck with it and send a message if you need help. Quote
Members Jacqui Posted October 8 Author Members Report Posted October 8 Toxo - thank you for the hints. That sure makes a lot of sense and thanks for the offer of help too. I have a feeling I may need it lol Quote
RockyAussie Posted October 9 Report Posted October 9 21 hours ago, Jacqui said: So I've never worked with leather before but have made bags for around four years with vinyl. My leather bundle has arrived today and my new skiving machine is due with me in two days. It is a Krafft 801. Any tips etc on how to use it for a newbie. Tips, tricks etc - stumbling blocks to try to avoid. Thanks all The most important thing is having it set up right and very very sharp. This video I made should be of help - Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members FDC Posted October 15 Members Report Posted October 15 (edited) Well you don't mess around! I too bought an 801 skiver a couple of years ago and it has been challenging to get comfortable with. I would suggest the following to climb up the learning curve faster: Go to YouTube and watch videos about adjusting and using an 801 skiver Label all of the adjustments on your skiver so that you know exactly what they do! Indicate feed direction as well. I just used a fine Sharpie. Make sure that your bell knife is sharp! Make sure that your bell knife is ALWAYS sharp! Set up your machine with each new type of material that you're skiving, it's NOT a "set it and forget it" machine! Using cheap ABS or PVC plumbing parts from a home center make your own vacuum system if your machine doesn't have one already. Dead simple, inexpensive and prevents offcuts from messing up your skiving. Be patient and expect some frustration as you get it figured out! Edited 21 hours ago by Northmount Fixed spelling Quote
CdK Posted October 18 Report Posted October 18 On 10/15/2025 at 12:21 PM, FDC said: Well you don't mess around! I too bought an 801 skivver a couple of years ago and it has been challenging to get comfortable with. I would suggest the following to climb up the learning curve faster: Go to YouTube and watch videos about adjusting and using an 801 skivver Label all of the adjustments on your skivver so that you know exactly what they do! Indicate feed direction as well. I just used a fine Sharpie. Make sure that your bell knife is sharp! Make sure that your bell knife is ALWAYS sharp! Set up your machine with each new type of material that you're skivving, it's NOT a "set it and forget it" machine! Using cheap ABS or PVC plumbing parts from a home center make your own vacuum system if your machine doesn't have one already. Dead simple, inexpensive aand prevents offcuts from messing up your skivving. Be patient and expect some frustration as you get it figured out! Agreed, the last line is too true, it took a while for the eureka moment where it came together. I’ll add to this, the presser feet that came with my 801 were unfinished and took smoothing and buffing to work well without damaging the finish. Also, there are specialized feet that have their niche, such as roller feet and some that create a groove that allows easy folded edges. Similarly to sewing machines the 801’s can benefit from appropriate presser feet. Quote Leather work machines I own: Thor 1341, Thor 441, LSZ-1 clone, 801 bell skiver, Tinker's Delight Shoe Patcher. (Tippmann Boss was re-homed.)
Members FDC Posted 23 hours ago Members Report Posted 23 hours ago Apologies for my deplorable spelling in my response above. Skiver, skiving. 🙄 Quote
Northmount Posted 21 hours ago Report Posted 21 hours ago 2 hours ago, FDC said: Apologies for my deplorable spelling in my response above. Skiver, skiving. 🙄 Fixed it for you! Quote
