Members dikman Posted 3 hours ago Members Report Posted 3 hours ago All my holsters were made glued flat and then folded, it's inevitable that wrinkling will occur although sometimes it's possible to minimise them. The last holster I made was a SlimJim style and I wanted to carve it so used thicker leather for the outside but this time I tried pre-curving it while glueing to the inner (as Dwight suggested). It did make a neater finish although it was a bit more messing around getting it right. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Latigo Smith Posted 1 hour ago Author Members Report Posted 1 hour ago (edited) 2 hours ago, Dwight said: Yes . . . I totally pre bend my holsters that are lined. AND . . . you isolated the big reason . . . wrinkles. If you glue them flat . . . you have a 999 out of 1000 chance that the inside will wrinkle like the 98 yr old witch living down the road. I moisten and wet mold the inside piece . . . as it touches the weapon . . . so it needs it's positioning settled up front and wet molding it does that trick. I then let it dry . . . completely . . . At the same time . . . I will also wet mold the outer layer so that the sight track portion knows it is not laying flat the rest of it's life. It's only a so-so molding . . . just enough to set the curve for the final bonding. I do the same for the back flap of the holster . . . bending the inside piece before bonding with the outer piece. It makes for a much better curve for the flap. Concerning the weight . . . generally speaking the thicker the leather . . . the stiffer the final product. But that can also be achieved by cheating. Putting the two pieces together . . . and either slipping it thru the Mexican loops or adding the front buckle loop . . . you then wet the whole thing . . . and hang it in a 140 degree farenhite "hot box" . . . take it out after a couple hours . . . if it was made out of 5/6 or 7/8 . . . the holster itself is a weapon . . . you could knock someone out . . . banging them on the head with that holster. May God bless, Dwight Alrighty, it sounds like pre-bending is the way to go. Do you find that simply applying pressure with your hands when cementing the layers results in a strong enough bond? This was the only reason I had planned on gluing flat, that I have more confidence in the hold of the contact cement when it's had a little time with some weight applied to it while curing. You use the gun to wet mold the individual layers to the correct curve radius before glue up? That sounds like an excellent way of doing it. Do you leave the gun in the leather while it's drying like when doing final molding or do you just mold it to the proper curve, take the gun out and let it dry? Edited 1 hour ago by Latigo Smith Quote
