I have a customer who wants his holster to not be shiny.  I usually use Resolene but that is a glossy finish. Any suggestions?
Not so retired RN. Living on the Washington Peninsula.
Try a final buffing with talcum powder
I used to use Tandy's Satin Sheen. Looking on their website now, I see Eco-Flo Satin Sheen. It appears to be the same product, but I am not certain. Probably is though. Not completely Matte but low-sheen.
Instead, you could use Neutral shoe polish. With shoe polish, the customer can touch-up their holster easily.
https://tandyleather.com/products/eco-flo-satin-shene?_pos=1&_sid=88e6f60ec&_ss=r
Edited by wizard of tragacanth
Wisdom from an old Missouri farmer, my Grandpa: If it's not sharp, it's not a knife.
There are a couple way to do this.
1. Resolene/water 1:1. Do a couple coats then put some type of wax over that. It'll soften the shine but it doesn't stay, they would have to wax it every so often.
2. Resolene/water 1:1. Do a couple coats let it cure 24 hours. Add a 3rd coat and lightly knock it down with either #0000 steel wool or a Magic Eraser. Again you have to do this lightly
3. Go with a different finish like Satin sheen.
You can also add varying amount of talc into resolene which will give varying degrees of mattness. Talc added to any paint or varnish in small-ish amounts acts as a matting agent
Thanks folks. I've thought of trying the steel wool or such. I use 50/50 pretty much anyway.  Haven't thought of talc. Good ideas.
  • CFM
Leave it with a natural finish, use a good outdoor boot dressing like Fiebings golden mink oil or some such. That's all I ever use on my holsters.
Tan-kote isn’t shiny. I cut mine by a third.
  • CFM
oh, and if you do this, use a new pair of leather gloves to apply and rub in the dressing. You will get a beautiful hand-rubbed finish as well as a nice pair of conditioned leather gloves for winter.😉
