Members stampingdelight Posted February 11 Author Members Report Posted February 11 @fredk thanks will try that or at least get some to try, any place the best to buy Quote
Members stampingdelight Posted February 11 Author Members Report Posted February 11 @Hags what is the name of the 3m stuff or where does one find did try searching just came up empty Quote
Members TonyV Posted February 11 Members Report Posted February 11 Mostly I use Weldwood contact adhesive, especially on larger pieces. Sometimes I use white "leather glue" (PVA?) when the project isn't intended to undergo a lot of stress. Sometimes I use double sided tape, where all I need is to hold small or light pieces together while I sew or rivet. Contact adhesive can be messy and difficult to manage on small, thin pieces. You have to align the pieces accurately on the first try but it is very strong and long-lasting. White glue works here, but takes a long time to dry, which also gives plenty of time to align pieces. Where the tape shines is on thin leather where glue might leave traces. Quote
Contributing Member fredk Posted February 11 Contributing Member Report Posted February 11 13 hours ago, stampingdelight said: thanks will try that or at least get some to try, any place the best to buy I just get the double-sided sheets off an ebay seller It takes a bit of practice to use the sheets tho Quote Al speling misteaks aer all mi own werk..
Members Handstitched Posted February 12 Members Report Posted February 12 The double sided tape may also be known as ' basting tape'. Cheap as from a local discount shop, i usually grab half doz rolls in different widths. I use it for doing hems and seams on thin leathers etc where pins can't be used, and where c/a can be a bit messy, handy stuff HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Hags Posted February 12 Members Report Posted February 12 On 2/10/2026 at 8:43 PM, stampingdelight said: @Hags what is the name of the 3m stuff or where does one find did try searching just came up empty Makersleathersupply.com Quote Not so retired RN. Living on the Washington Peninsula.
Members stampingdelight Posted February 13 Author Members Report Posted February 13 @Hags @Handstitched @fredk thanks so much Quote
