Members BigRiverLeather Posted December 4, 2010 Members Report Posted December 4, 2010 I've talked with a few makers about finish coats and a couple have said they dip their holsters, sometimes for as much as 2 minutes, in acrylic (one specifically Angelus cut with water 50/50). I've considered trying this but I'm concerned about runs. I get enough of that if I overspray with my airbrush, especially on third coats where there is a finish on the leather already. If you are dipping, what are your specifics? cut with water? drying method? Quote Big River Leather
Members Dwight Posted December 6, 2010 Members Report Posted December 6, 2010 Some time back a poster said they dipped their products and then used an air hose to lightly blow off any extra liquid. I have experimented with it, . . . and I like the effect it gives, . . . which is a very light coating of finish. For my IWB holsters, and my carry belts (the most of my business) I prefer to use a brush and a 50/50 mix of Resolene and water. But, . . . I'm working on using an air brush, . . . just have to wait and see where that takes me. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Haystacker Posted December 8, 2010 Members Report Posted December 8, 2010 I've finally settled on my finish. Been doing this consistently for about a year now. I dip my holsters and belts. Just a quick in and out making sure everything was covered. Then I let it dry. I try to let it set for 24 hours and then give it another dip. Works great, no runs. I use mop and glow cut with water - 50/50 mix. Quote haysholsters@hotmail.com NRA Life Member
Members woolfe Posted December 8, 2010 Members Report Posted December 8, 2010 I dip in 50/50 resolene/water then spray off with an air compressor. I'm just wondering how the mop and glow works. When I was in the military we would use it on our boots, just the heal and toe, to add a quick shine and protect the thick coat of shoe polish. It would end up cracking after awhile. Just wondering if you are having any trouble with it cracking or does cutting it with water some how make it more resilient to cracking? Quote http://www.woolfegunleather.com/
Members Haystacker Posted December 8, 2010 Members Report Posted December 8, 2010 I dip in 50/50 resolene/water then spray off with an air compressor. I'm just wondering how the mop and glow works. When I was in the military we would use it on our boots, just the heal and toe, to add a quick shine and protect the thick coat of shoe polish. It would end up cracking after awhile. Just wondering if you are having any trouble with it cracking or does cutting it with water some how make it more resilient to cracking? I like the mop and glow a lot. I tried all the sheens and also the angelus acrilc. I never was satisfied with the feel. I always thought they were too tacky. Then I read on here a posting from some old grumpy guy about the mop and glow. I tried it and now I like it. I believe it wears as well as anything else. Jeff Quote haysholsters@hotmail.com NRA Life Member
Members K-Man Posted December 8, 2010 Members Report Posted December 8, 2010 I'm just wondering how the mop and glow works. When I was in the military we would use it on our boots, just the heal and toe, to add a quick shine and protect the thick coat of shoe polish. It would end up cracking after awhile. Just wondering if you are having any trouble with it cracking or does cutting it with water some how make it more resilient to cracking? My personal experience is that Mop & Glow will discolor and crack - even when split/cut with water. It's a very poor substitute for a finish on a holster. Quote
Members katsass Posted December 8, 2010 Members Report Posted December 8, 2010 (edited) My personal experience is that Mop & Glow will discolor and crack - even when split/cut with water. It's a very poor substitute for a finish on a holster. FWIW; The first thing that I have found when using any of the acrylic finishes (including Mop and Glow, which I have used for years) is that most people tend to use way too much. The stuff isn't paint, It isn't designed to smear on in a thick coating. Thinned 50/50 with water, applied to warm leather with and airbrush or by a QUICK dip, and it should penetrate and dry quickly. When used, if you see a a milky white covering.........you got too much on. With an airbrush I mist, dust, or apply a very fine covering to WARM leather, the stuff disappears almost immediately, the same with dipping. It penetrates and seals. When dry, I'll usually then apply a little neutral wax by rubbing a finger in the stuff and rubbing that into the leather and buff to a final low gloss. No rag or applicator is used, you'll get too much on the leather. The secret is.......moderation. JMHO......from a grumpy old man. Mike P.S. IMO leather should look like leather.......not leather with a plastic coating. The acrylics will penetrate and show almost no shine........until too much is used. Edited December 8, 2010 by katsass Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members K-Man Posted December 8, 2010 Members Report Posted December 8, 2010 FWIW; The first thing that I have found when using any of the acrylic finishes (including Mop and Glow, which I have used for years) is that most people tend to use way too much. The stuff isn't paint, It isn't designed to smear on in a thick coating. Thinned 50/50 with water, applied to warm leather with and airbrush or by a QUICK dip, and it should penetrate and dry quickly. When used, if you see a a milky white covering.........you got too much on. With an airbrush I mist, dust, or apply a very fine covering to WARM leather, which disappears almost immediately, the same with dipping. It penetrates and seals. When dry, I'll usually then apply a little neutral wax by rubbing a finger in the stuff and rubbing that into the leather and buff to a final low gloss. No rag or applicator is used, you'll get too much on the leather. The secret is.......moderation. JMHO......from a grumpy old man. Mike In comparison of my use of Angelus acrylic #600, I've never had the cracking/peeling or discoloration. I stand behind my comment that mop & glow is a very poor substitute for a finish on a holster, regardless of how it's applied. But my being a back yard, redneck holster maker, what do I know? Quote
Members Haystacker Posted December 8, 2010 Members Report Posted December 8, 2010 (edited) I'm just glad they make chocolate and vanilla. I think I remember who the grumpy old guy was that I got the mop and glow idea from. My respects to you sir. Jeff Edited December 8, 2010 by Haystacker Quote haysholsters@hotmail.com NRA Life Member
Members OldNSlowMarine Posted January 8, 2021 Members Report Posted January 8, 2021 Sorry for bringing this topic back from the dead. It was the most relevant one I could find. I have a 5 gallon bucket filled with a 50/50 mixture of Angelus #605 and water. I have attempted to dip-finish my holsters but have had only one or two that were successful, and they were both solid black. I recently attempted a mahogany colored holster and it turned out very "blotchy." Specifically the mixture penetrated around the edges and stitch lines. I believe this is due to the needle holes allowing the mixture in there first and spreading from there, but I could be wrong. Hence, why I'm seeking advice. So, here's the pertinent information: -8 ounce Wickett and Craig -Dip-dyed in Angelus (custom in-house Mahogany blend) -Wet molded -Dried in drying cabinet at approximately 105 degrees for 1 hour, then hung up for 2 days -Warmed in drying cabinet for 30 minutes at 105 degrees -Dipped in finish mixture for approximately 5 seconds (the one previous to this was a quick in and out, had similar results) I'm thinking my next attempt will be for at least 10 seconds, but I'm curious if anyone else has any information or tips first. My desire to get this right is because I love the firmness I got from the couple that turned out good. I think those were dipped for about 10 seconds as well. Thanks! Quote
