8 hours ago, 4squareleather said:
just got a Consew 206rb3 and it didn't come with any needles or thread.  i'm going to be using the machine to sew belts, wallets and tool pouches.  when hand stitching I usually do .8 ritza tiger thread.  What would be the best needle thread combo.  thanks in advance for any help.
You can use a #138 w/a #22 needle.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
  • 2 weeks later...
  • Replies 110
  • Created
  • Last Reply
Top Posters In This Topic
Help needed with this thread type .
I can buy these voor 10 € a piece.  It's a type of thread coming from the Dutch Army .
Probably a ( Specal ) Cotton thread .
Is it worth the money and what can you Sew with this thread?
Edited by Oldiesfan
For as far i know it's a Cotton Z- Twist size 8 thread.
I
This looks similar to the thread used for sewing soles on shoes but not sure?? I have some rolls for sewing sandals but it is linen thread not cotton.
20210515_161111.jpg.4379ffa50ab09a6a62cbd39d7a3699a8.jpg20210515_161554.jpg.e6370e6d6c9f1fd32091121f3d985718.jpg
Edited by jimi
 I ordered 3 rolls instead of all 12 . Let's say it's Cotton thread in this type i asked questions about . For what kind of sewing work can you use that thread ?
See label and Nsn
10 € a roll = cheap or expensive?
Edited by Oldiesfan
This is what i found on the internet . It also seems to be that a type IV and V are shoe threads . Type 1, 2 and III Machine threads. Look at the picture for info about a A.A. 52094A version .
Does that mean that a type V can't be used in my Singer 132K versions or 45k89 ?
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.amefird.com/wp-content/uploads/2012/09/8-30-11-A-A-52094A-Spun-Cotton-Shoes.pdf&ved=2ahUKEwiehdSztMzwAhVj8-AKHQ2RAlkQFjAAegQIAxAC&usg=AOvVaw2Qz6Ypu8NOvHjUbAppoOqy
Edited by Oldiesfan
If you don´t use it you can always string together the ham or the turkey for christmas :lol: €10 is a good price for that size of roll i think, those small Hoogen rolls are 20 each! ouch..then add postage...ouch again.
It looks straight enough to use in the machine??? i have used the linen 18/4 in my 45k and it worked well, with only one turn around the tension disk. I am sure you can stitch a bag together with that thread?? or a belt...if you groove it for laying the thread down because it might fray easier. It would probably absorb any oil or wax you apply to it?? Or try making sandals?? your 89 can do that?? That would probably bee the same thickness as 207-277 bonded nylon?
Edited by jimi
Regarding the "shoe thread," ask the seller to check the label to see which way it is twisted. Most single needle sewing machines with hooks spinning clockwise require left, or reverse, or Z twist thread. But, some shoe sole stitchers require right twist thread. If you use right twist in a standard sewing machine it may unravel as you sew.
Note, some twin needle machines may require right twist for the outside needle if that hook spins counterclockwise..
Posted IMHO, by Wiz
Look at what's mentioned in the printscreen . Z Twist .
One page back you see a picture of the label .
Edited by Oldiesfan
Those threads are glazed, or mercerized, but not bonded. You will have a hard time using cotton or linen thread is a normal sewing machine. The shoe threads are usually waxed before you sew. In the case of a sole stitcher, the wax is in a pot that feeds to a barbed needle. This strengthens the fibers. If you run this thread through a standard sewing machine, without wax, it will probably break during the take-up cycle. At least that was my experience with Barbour's Irish Linen glazed thread when I last tried it.
Posted IMHO, by Wiz
