Members withsilverbells Posted August 8, 2011 Members Report Posted August 8, 2011 I am using a Consew 206RB-5, 135x17 DP needles, and #69 nylon thread. The needle or the machine seems to be slightly shredding the thread, until only a few strands remain taught as it sews and the other strands curl up the length a ways and bunch together. I was sewing something much thinner than usual at the time. I tried adjusting the needle... I am still new at all this, but it seems that how high the needle is screwed in makes a difference, and also whether the needle is rotated correctly. So I have tried to adjust those things. It did not work, but I may not have adjusted the right way... How do I solve this? Thanks in advance! Quote Mary Welsh "He's not a tame lion." - C.S. Lewis
Members DJ1935 Posted August 8, 2011 Members Report Posted August 8, 2011 Check the thread path of your machine for any sharp or rough edges. You might need to gently smooth these areas with a jewellers file. Quote [font="Comic Sans MS"][size="3"][color="#a0522d"]"Growing old is compulsory - growing up isnt" [/color][/size][/font]
Members cdthayer Posted August 8, 2011 Members Report Posted August 8, 2011 I get that with some V92 threads on my Consew 225, but not with other threads. I think it’s the thread. CD in Oklahoma thayerrags.com Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Contributing Member Ferg Posted August 8, 2011 Contributing Member Report Posted August 8, 2011 I assume you are sewing a material other than leather since you are using 135 x17 needle. The long slot in the side of the needle should be to the left side, thread needle from left to right. A good test for sizing on thread and needle is to thread a needle, hold the thread at about a 45 degree angle. If the needle slides down the thread easily you have the right size needle for the size thread you are using. Do not adjust needle, it should be placed all the way up into the hole for the needle. If you place the needle other than that the timing will be off. Make sure your machine is threaded properly. On occasion my Consew will "flip" a thread off the lower tension discs making it wrap around the knurled knob. That throws the tension off and also will shred the thread. If you have messed too much with the needle etc. you may have messed up the timing. Your manual gives information on timing. ferg On 8/8/2011 at 12:20 AM, withsilverbells said: I am using a Consew 206RB-5, 135x17 DP needles, and #69 nylon thread. The needle or the machine seems to be slightly shredding the thread, until only a few strands remain taught as it sews and the other strands curl up the length a ways and bunch together. I was sewing something much thinner than usual at the time. I tried adjusting the needle... I am still new at all this, but it seems that how high the needle is screwed in makes a difference, and also whether the needle is rotated correctly. So I have tried to adjust those things. It did not work, but I may not have adjusted the right way... How do I solve this? Thanks in advance! Quote
Members Randy Cornelius Posted August 8, 2011 Members Report Posted August 8, 2011 1st, replace the needle with a new one. I have found that most problems can be solved with a new needle. Then look for burrs on the shuttle hook. Take it out of the machine and run your fingers across the end of the hook, there should be no burrs. If so sand them smooth with some 1000 or finer emery cloth or wet / dry sandpaper. Most of the time a frayed thread is caused by a burr or something like that. Randy Quote Randy Cornelius Cornelius Saddlery LaCygne, Kansas Randy & Riley Cornelius Ride Hard, Shoot Fast and Always Tell the Truth...
Members withsilverbells Posted August 15, 2011 Author Members Report Posted August 15, 2011 On 8/8/2011 at 2:04 PM, 50 years leather said: I assume you are sewing a material other than leather since you are using 135 x17 needle. The long slot in the side of the needle should be to the left side, thread needle from left to right. A good test for sizing on thread and needle is to thread a needle, hold the thread at about a 45 degree angle. If the needle slides down the thread easily you have the right size needle for the size thread you are using. Do not adjust needle, it should be placed all the way up into the hole for the needle. If you place the needle other than that the timing will be off. Make sure your machine is threaded properly. On occasion my Consew will "flip" a thread off the lower tension discs making it wrap around the knurled knob. That throws the tension off and also will shred the thread. If you have messed too much with the needle etc. you may have messed up the timing. Your manual gives information on timing. ferg Hi Ferg, It turns out I was sewing thick fabric and not leather at the time, but as a matter of fact I didn't realize that would be the wrong needle for leather. What range of needle sizes do you recommend for leather? I have a set of DP 135/17 needles the former owner sent with the machine, and also a set of DP 135/16 needles which were recommended for leather by the original salesman for the machine (his local company name and number were on the machine, so I payed a visit). I appreciate your help. - Mary Quote Mary Welsh "He's not a tame lion." - C.S. Lewis
Contributing Member Ferg Posted August 15, 2011 Contributing Member Report Posted August 15, 2011 (edited) Hi Mary, You need the 135 x 16 needles for leather. I am enclosing a chart for needle sizes in reference to thread. Your machine will handle #207 thread but makes it work hard, #138 is really the largest unless you modify your machine and/or stitch one stitch at a time. ferg On 8/15/2011 at 8:11 PM, withsilverbells said: Hi Ferg, It turns out I was sewing thick fabric and not leather at the time, but as a matter of fact I didn't realize that would be the wrong needle for leather. What range of needle sizes do you recommend for leather? I have a set of DP 135/17 needles the former owner sent with the machine, and also a set of DP 135/16 needles which were recommended for leather by the original salesman for the machine (his local company name and number were on the machine, so I payed a visit). I appreciate your help. - Mary Edited August 15, 2011 by 50 years leather Quote
