Members Anne Bonnys Locker Posted July 1, 2012 Members Report Posted July 1, 2012 A question that is often asked is how heavy a leather a machine will sew and while this is not definitive and there are exceptions the following might help. DBX1, DPX5, Domestic Needle: Light only - Garment leather with #69 DPX16, DPX16: Light to medium, generally to 7-8mm depending on the design of the machine with 138-207 thread DDX1, 328: Medium Heavy. Depending on the machine 10-12mm. Anything up to #415 794, 7X3 Very Heavy. 18-22mm Any thread commercially available. This is not meant to be definitive. There are all sorts of exceptions and I would appreciate feedback from our more knowledgeable members and dealers. Quote Darren Brosowski
Members amuckart Posted July 1, 2012 Members Report Posted July 1, 2012 (edited) Not that I'm in any way significantly knowledgeable, but having machines that take each of the systems below, I'd back your last two off a notch and add one on the end: DDX1, 328: Medium. Up to 13mm depending on machine. Thread up to 415/6 cord 794, 7x3: Heavy. 5-21mm depending on needle and machine. Thread up to 514/8 cord 331: Very Heavy 5-25mm depending on needle and machine setup. Thread up to 514/8 cord I'm fairly sure 1000 system needles fit in somewhere between 794 and 331 but I've never actually encountered any. That's only for threaded needle machines. Needle & awl machines are another story entirely. Edited July 1, 2012 by amuckart Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
Members mogwild Posted July 1, 2012 Members Report Posted July 1, 2012 Funny you posted, I was just exploring needles the other day Here's a picture I took. On the left, a regular household machine needle (110/18) and on the right, the needle I took out of the Landis No1 we acquired to see what size it was, it...big. Quote
Members mogwild Posted July 1, 2012 Members Report Posted July 1, 2012 Funny you posted, I was just exploring needles the other day Here's a picture I took. On the left, a regular household machine needle (110/18) and on the right, the needle I took out of the Landis No1 we acquired to see what size it was, it's...big. Quote
Members Anne Bonnys Locker Posted July 1, 2012 Author Members Report Posted July 1, 2012 Thanks for that! A lot depends on the machine. I brought in a Chinese machine that uses a DDX1 and was claimed to sew 18mm - the foot was cut away and the needle bar all but hit the leather - but I was able to sew 18mm! Not that I'm in any way significantly knowledgeable, but having machines that take each of the systems below, I'd back your last two off a notch and add one on the end: DDX1, 328: Medium. Up to 13mm depending on machine. Thread up to 415/6 cord 794, 7x3: Heavy. 5-21mm depending on needle and machine. Thread up to 514/8 cord 331: Very Heavy 5-25mm depending on needle and machine setup. Thread up to 514/8 cord I'm fairly sure 1000 system needles fit in somewhere between 794 and 331 but I've never actually encountered any. That's only for threaded needle machines. Needle & awl machines are another story entirely. Quote Darren Brosowski
Members amuckart Posted July 2, 2012 Members Report Posted July 2, 2012 .On the left, a regular household machine needle (110/18) and on the right, the needle I took out of the Landis No1 we acquired to see what size it was, it...big. Yup, that's a 331 system needle, same as is used in the Pearson No.6. They're scary big. There's enough groove for them to go through 25mm of leather and still throw a loop - and they used to come in sizes down to 160 which is awful thin for something that long! Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
Moderator Art Posted July 2, 2012 Moderator Report Posted July 2, 2012 Note that the shank of the DB1 will fit in the thread groove of the 331. Art Quote For heaven's sakes pilgrim, make yourself a strop!
Moderator Wizcrafts Posted July 2, 2012 Moderator Report Posted July 2, 2012 I used to have a hand operated sole stitcher, with a vertical up/down lever on the needlebar, that used a huge needle like the one pictured in this topic. It sewed with 6 cord pre-waxed linen thread, just along the edge, one stitch for each pull up/down on the lever. I wish I didn't give it away back then. It clamped onto the edge of a sewing machine table and stood upright, about 10 or so inches. I'm guessing that the needle was about 2.5 inches long and about 3/32 inch wide at the top. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members mogwild Posted July 2, 2012 Members Report Posted July 2, 2012 (edited) Yup, that's a 331 system needle, same as is used in the Pearson No.6. They're scary big. There's enough groove for them to go through 25mm of leather and still throw a loop - and they used to come in sizes down to 160 which is awful thin for something that long! Still learning. None of the needles I got with mine have 3 digit numbers, they all say: Landis 8 Landis 3 Landis 6 Landis 5 etc. Some of them are pretty thin! Edited July 2, 2012 by mogwild Quote
CowboyBob Posted July 2, 2012 Report Posted July 2, 2012 I used to have a hand operated sole stitcher, with a vertical up/down lever on the needlebar, that used a huge needle like the one pictured in this topic. It sewed with 6 cord pre-waxed linen thread, just along the edge, one stitch for each pull up/down on the lever. I wish I didn't give it away back then. It clamped onto the edge of a sewing machine table and stood upright, about 10 or so inches. I'm guessing that the needle was about 2.5 inches long and about 3/32 inch wide at the top. Wiz, Did it look like this? Bob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
