Reviving an older thread for a follow-on question... :) I am needing to build a new table for a Singer 144W302 (30" long arm) I recently acquired. The existing table has some rot where the hinge cutouts are. Luckily I can use it as a template for the cutouts so that's good! :)
My question(s):
1. Thought's on a minimum table thickness for this BEAST of a machine?
2. Butcher block or stacked sheets of plywood? 99% sure will be adding a white laminate to the surface.
3. Existing table is pretty MASSIVE (~72"x34") I already have 2 other tables that this one will marry up to for the flow of the larger projects. So was thinking of cutting it back a bit, something like ~30" x ~60" see any red flags with doing that?
Table will reuse the existing leg/foot hardware that's on casters...
Appreciate any insight/thoughts you all may have!!!
  • Replies 182
  • Created
  • Last Reply
Top Posters In This Topic
14 minutes ago, Scottwb96 said:
My question(s):
First off the head is going to weight in around 180 kg (400lb) and the table top has a large hole cut out of it so the table top needs to be real sturdy. I would make sure with whatever material you are going to use it is going to be able to take the load and you may wind up using additional metal support under the table top bolted or welded to the existing frame. If I'm not mistaken the original table top was 2" thick hardwood plywood with a laminated top glue to it.
I would NOT use Butcher block as it will not be as strong as plywood, will have a higher tendency to wrap / crack but it will look pretty. The thickest plywood I have seen is 1 1/4" which is actually slightly smaller due to the sanding process. If you choose to use the standard easily available 3/4" plywood and glue them together make sure the grain of one is 90 degrees opposite to the other.
I would suggest: i) additional angle iron metal bracing under the table top to help support the front and rear edge weight of the machine along the cutout section ii) use three pieces of 3/4" plywood glue together but that would depend on the type of plywood (softwood or hardwood) and iii) do some calculations on the strength of the type of plywood for the load to determine the type and size of plywood needed. Remember that plywood will warp / buckle / fail if not properly supported.
Just my thoughts.
kgg
A good plywood should be stronger (particularly if you laminate a couple of layers) and I agree with kgg about using metal angle iron underneath to give additional support, given the weight of the head unit. I used the same idea on one of my tables.
Appreciate the input! The machine head isn't 400lbs (LOL) I lifted it by myself out of the back of SUV and carried it into my shop. And as "strong" as I'd like to think I am, I am definitely not 400# lifting, walking, setting down strong!!! ;)
I was definitely planning of adding some angle iron underneath. I had also found a butcher block that was 3" thick I was considering using. The current (decaying) table was only about 1.75" thick. Was hoping that almost doubling the thickness and adding the additional supports (that aren't currently on the stand) that it would work well...
Thoughts?
2 pcs of 3/4" Birch plywood glued and screwed with a 3/4" band running all the way around the outside would look like a solid chunk of wood for the table. No plywood edges. Done right and you can hardly see the seam.
Being able to build your table can save you a lot of money. This table is a work in progress. Had a Singer 108W20 then a Singer 153W103 then a Class 4 then a Class 26 and now a Sewing Machine GA441.  The flat bed  table is a Cobra Class 4 flat bed with the rest of the scrap Formica . All the scrap Formica came from a job I did. Came up with a faster and stronger method for attaching it. No tools needed.  Big hand knobs from underneath with threaded inserts in the bottom of the flat bed table legs to hold it place. Last two pictures are the original motor and speed reducer set up. This set up will move closer to the wall because of the new location of the motor.
K legs                                                        $100
Presser foot lifter pedal                          $20
Plywood & 1x3 for the lower top &        and thread cab                                         $40
Motor                                                         $129
Speed reducer 12" pulley off Ebay        $31
2" pulley (Dad's garage)                               0
Bearing Blocks  (Amazon)                      $13
Mercury Outboard 3/4" shaft                    0
Idler pulley (Tractor Supply)                   $12
Aluminum shafts and brake cable        $35
Lights                                                          $25
Full extension drawer guides                   $14
Cable for presser foot lifter                    $9
Rubber feet for legs                                $7
Belt for speed reducer                           $12
3 way plug                                                 $4
Table, Motor and speed reducer            $451 + a lot of head scratching and work.
This is my other sewing table. Corion top from an ice cream shop I remodeled. I put a lot more room to the right of the machine to set up a bobbin winding station. A little home sewing machine motor with a bobbin winder tire on the pulley. Winds 441 bobbins as fast as you want it to. As little as 5 seconds if you aren't careful.  I also have a Singer 31-20 with a roller foot I use in this table for sewing boot tops. That's what the arm rest bolted to front of the table is for. Lots of hand wheeling sewing boot tops.
Very nice work, Tim, those big pulleys should give very slow speed!
Scott, if you've got a a butcher block that thick then by all means give it a try (but I would still put the angle iron underneath).
  You are a very talented individual Sir. I will be bootlegging some of your home grown speed reducer ideas for that Cobra class  26 you sold me. Thanks for being a stand up guy to deal with.
Great job to all the other folks for posting pics of some fantastic tables.
@dikman It was more about torque. Well really about money. This has always been a hobby. Speed reducers were $175 and I have around $50 in the flat bed table speed reducer I did first. Motor is turning twice as fast as with speed reducers you can buy at the same sewing speed giving me more torque than with those speed reducers. Before I built the speed reducer I would try to sew slow with just a servo motor and it just didn't have the torque or punching power at the slow speed. Now full pedal is the fastest I would ever sew anything creating a lot more variable speed control in the foot pedal. It's not so sensitive to tiny movement.  I'm not sure about the servo motors today but I was using one of those old grunting noisy servo motors in the beginning. Repurposed it for a Naumkeag on my boot sanding machine.
@Southerngunner Really handy to be able to build your own table.  $1200 for the Class 26 I had for sale and $500 for a table with a new motor and speed reducer and somebody could have been in a New Condition Class 26 for $1700  and a little work and that's with a flip down roller guide and includes all shipping. That table is a lot more sturdy than the pedestal stands.
  • 3 weeks later...
Well here goes, I have started my own version of a Heavy duty table. I have 20' of 2 1/4" square tubing left over from a metal building that I had built, so since I was a welder / heavy equipment mechanic for years I decided to build the legs from that.
I will be implementing Tim's  12"/2" torque pulley set up and a new servo motor. I have started welding up the legs so I will update when I get far enough along for pictures. I will be putting casters on it because by time I add a top and the class 26 Cobra this sucker is going to be heavy;)
