Check to see how much lost movement you have in the vertical lifting rod on the back,you might just need to raise the pad on the knee lifter where it pushes on the rod.It is underneath real close to the motor.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
Does this help you?
  • 2 weeks later...
Not really I have that info I replaced the arm shaft and bearing and I dont think I have that eccentric clocked properly
Thank you though
I believe that will only help if the eccentric is clocked properly to begin with constabulary
"clocked" ?
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Yes the presser bar lifting eccentric is out of adjustment
On the UK side of the pond "clocked" means "recorded at"..as in "the car was clocked at 120mph"..or "the runner was clocked at 10.8 seconds over a 100 yards"..means to use a stop watch or other device "to record time over distance" the act of "clocking"..( thought that was the same as the USA use of "clocked" ) ..also slang for "winding back the odometer"..illegal practice used by some when selling cars..
I know military use clock hand positions to indicate position..such as "at 2 'o clock" or at "6 o' clock high".
But it is the first time I've ever heard anyone ( including US military, with whom I have had a great deal of contact ) use "clocked" ( without a number for reference ) to indicate what presumably you mean by "correct position" or "incorrect position".
Brought to mind "The RAF Banter sketch from Monty Python".
Edited by mikesc
Also slang for looking at, recognising, or taking note (not written) of something. :wave:
“Equality?   Political correctness gone mad, I tell you, gone mad!!!!    Next they'll be wanting the vote!!!!! :crazy:“.
Anger and intolerance are the enemy of correct understanding
Also slang for hitting someone. Mike, however, has pointed out the more common usage of the term.
Yes..indeed..there is that ( are those ) too..I begin to forget my English slang due to rarely using English for 3 decades, thankfully (as all the Celtic people are aware ) there are always Celts ( Irish, Scots, Welsh, Australians* etc ) to preserve, guard, subvert, render even more poetic, and in general cherish the English language. ;-)
*yes..Australians count as Celts too (even those whose ancestors were part of the "dream times" )..the Celtic influence is all over the antipodean versions of English.
Edited by mikesc
