Members RoosterShooter Posted February 5, 2014 Members Report Posted February 5, 2014 I'm needing an affordable servo for a Singer 211G151. Can someone please point me in the right direction on where to purchase one? Thanks. Quote
Northmount Posted February 5, 2014 Report Posted February 5, 2014 Try Toledo, see banner ads at top of the page. Tom Quote
Members RoosterShooter Posted February 5, 2014 Author Members Report Posted February 5, 2014 Anyone else? I like options. Quote
Moderator Wizcrafts Posted February 5, 2014 Moderator Report Posted February 5, 2014 I now use and recommend the Family Sew FS-550 servo motor that is sold by Toledo Industrial Sewing Machines. Ask for the 50mm (2 inch) pulley instead of the 75mm that is installed by default. It requires a special inside collar to allow 3/4 inch ID pulleys to be installed onto a roughly 5/8 inch shaft (actually some Metric diameter). You can re-use the interfacing collar with other 3/4 inch pulleys, should you wish to experiment. Tell the dealer what your existing motor pulley diameter is as well as the length of your v-belt. Sewing machine v-belts are type 3L (3/8") and are usually measured in inches, in the USA. The belt may be stamped with a 42, or M42, meaning 42 inches outside circumference, or some other number. Upholstery and garment making machines are normally setup with small hand wheel pulley and large motor pulleys. I often see 44 inch belts on these machines. After converting such a machine to use a FS-550, the belt will need to be shorter, one inch per inch less motor pulley diameter. So, if your existing pulley was 4 inches and the new motor is ordered with a 2" (50mm) pulley, the new belt needs to be 2 inches shorter. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members truenorth Posted February 5, 2014 Members Report Posted February 5, 2014 Is this a brushless motor? Do brushless motors have more control? Is the FS550 big enough for the Cb4500? Quote
Moderator Wizcrafts Posted February 5, 2014 Moderator Report Posted February 5, 2014 Is this a brushless motor? Do brushless motors have more control? Is the FS550 big enough for the Cb4500? No, it has two brushes. Two extras are included in the packaging, along with a spare brake pad. The motor has a multi-position speed limiter switch on the front panel, with a pointer knob. You can change the top speed in a second, even while you are sewing. I have one powering my CB4500. I ordered it from Toledo Industrial Sewing Machines with a 50mm pulley, which is not the standard size from the factory. Bob Kovar used a special interfacing collar to fit inside the new pulley, which has a 3/4 inch bore. The motor has a 38 inch type 3L v-belt feeding the large pulley on the speed reducer. The small pulley on the reducer feeds up to the machine. It can sew through 3/4 inch of veg-tan leather, with a #25 needle and #277 thread, at one stitch every five seconds, or into 1/4 inch double leather belts at 5 stitches per second. This is all easily controlled by your foot. For occasions where I need to sew patterns, like fishtails, I set it to the slowest setting and sew with the pedal all the way down. She chugs along at about one stitch per second. I hope this helps 'splain the motor. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members MuddyClearWaters Posted February 7, 2014 Members Report Posted February 7, 2014 I've been nothing but happy with my SewPRo 500GR. I purchased from toledo. Was a little under 200 with shipping. Worth every penny. Quote Custom Leather Bicycle Saddles and Accessories www.carsonleh.com Singer 110W124 Singer 52W19
Members gottaknow Posted February 7, 2014 Members Report Posted February 7, 2014 No, it has two brushes. Two extras are included in the packaging, along with a spare brake pad. The motor has a multi-position speed limiter switch on the front panel, with a pointer knob. You can change the top speed in a second, even while you are sewing. I have one powering my CB4500. I ordered it from Toledo Industrial Sewing Machines with a 50mm pulley, which is not the standard size from the factory. Bob Kovar used a special interfacing collar to fit inside the new pulley, which has a 3/4 inch bore. The motor has a 38 inch type 3L v-belt feeding the large pulley on the speed reducer. The small pulley on the reducer feeds up to the machine. It can sew through 3/4 inch of veg-tan leather, with a #25 needle and #277 thread, at one stitch every five seconds, or into 1/4 inch double leather belts at 5 stitches per second. This is all easily controlled by your foot. For occasions where I need to sew patterns, like fishtails, I set it to the slowest setting and sew with the pedal all the way down. She chugs along at about one stitch per second. I hope this helps 'splain the motor. I'm sorry, but I'll need more information. Quote
Members RoosterShooter Posted February 8, 2014 Author Members Report Posted February 8, 2014 (edited) Is there any specific information I will have to give them about my machine at Toledo before ordering the servo? Also, is this a 'plug and play' modification? In other words ... I have experience with switching motors out on rock cutting machines ... will this be somewhat like that? Thanks. Edited February 8, 2014 by RoosterShooter Quote
CowboyBob Posted February 9, 2014 Report Posted February 9, 2014 It is a very easy job & normally the holes in the table even line up.The motor comes pre-wired w/a new switch & is ready to bolt on.This motoe also has a threaded rod belt adjustment on the front like most other motors to adjust the belt length. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
