The more carbons an alcohol has, the more it behaves like an oil and the less it wants to mix with water.
Without the "-OH" group (that makes it an alcohol), 1 carbon = methane, 2 carbons= ethane, 3 carbons = propane, 4 = butane, 8 = octane,
20 = diesel. With each additional carbon, the compound becomes less volatile, moving from gasses (methane) to very light liquids (butane) to very heavy liquids.
If you're using alcohol as a solvent, methanol will probably dissolve anything, but it will evaporate very quickly. Ethanol will dissolve most anything but will take a little bit longer to evaporate. Use isopropyl alcohol and it will probably have that "medicine" smell for quite a while. I would suggest avoiding using isopropyl.
Fieblings deglazer is a mixture of ethanol and ethyl acetate, which is a compound made by reacting ethanol with acetic acid (vinegar). Pretty volatile, but it strips the wax off the surface of the leather fast enough that you can get it clean before it's evaporated. I add this just as an example of an ethanol-like solvent.
Edited by TexasJack
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Well FWIW I've used plain ole 70% isopropyl alcohol now for thinning dyes for over 50 years - never had a problem due to the added water, although recently I've gone to the 90% and thin with water to 70% - I was taught to always dampen first for better penetration anyway so for me it works
for cleaning and deglazing I mix a quart of 90% with a cup of cheap lemon juice
Edited by ChuckBurrows
Two roads diverged in a wood, and I,
I took the one less traveled by,
And that has made all the difference.
I , like Chuck have always used Isopropyl 70 for about 30 years. It was not until we got a wallyworld in town that I found an option for percentages so I usually go with the 90 now.
I try to reserve my denatured for my spirit lamp.
A while ago I checked out the MSDS of all the Tandy dyes, cements and solvents. (I hold some patents on soy based solvents.) The primary alcohol appears to be ethanol so I would assume that denatured ethanol would make the best solvent. One of the standard saying in the solvent industry is "Like dissolves like"
Cya!
Bob
  • 8 months later...
Hi, I'm new so bear with me, as a retired pharmacist we can tell you that Rubbing alcohol is 70% isopropyl alcohol and the rest water. A number of contributors recommended rubbing alcohol to thin out oil dyes. I had my doubts as we remember oil and water don't mix. Sure enough we found bits of dye being deposited on the sides of the pallette rejecting the water. Denatured alcohol works just fine.Ethanol is pure white lightening. One advantage to using that is when you are seeing your projects turn out really disastrous you can always take a swig to ease the pain.
Best
Grampa Joe
Granpajoe, you are either a hillbilly or a southerner. I use rubbing alcohol to thin.
Since ethanol and methanol are simple solvents, the addition of methanol to ethanol does not exponentially increase the "denatured alcohol" ability to mix with the dye.
As in my granddaughters statement: Whateverrrrrrrrrrrr. :)
Edited by Red Cent
No need to be rude about it. You asked the question, remember?
Mike DeLoach
Whoa!!! Ambassador Oaks.
I just noticed your post. Rude? I would think that the smiley would give reason to the statement/word as being facetious. Kangaroo time.
Edited by Red Cent
If I might add my $0.02 here, it is best to use a thinner/solvent that has been specifically matched to the product to be used. Everyone knows that alcohol, regardless of what blend, will dry the leather out. And I can tell you from experience that alcohol, again regardless of blend, is not a good thinner/extender because of the amount of water content that it contains. The water does not actually mix well with the dyes/stains. I know there are several craftsmen who are always looking to save a buck or two or a more easily available product that can be picked up on a whim instead of having to drive several miles to a Tandy store or order it online (and we all know that most of us don't actually live anywhere with a Tandy (or other leathercraft supplier) store in our back yards) but when it comes to ensuring that the finished product is the finest quality and best that it can be, take the plunge and buy the proper products that are meant to work together.
After all Red Cent, you have it as part of your profile info on the side bar: "Life is too short to argue with stupid people and drink cheap booze." I am not calling you stupid in any way shape or form but think about the "cheap booze" part and then apply that to "cheap finishes/materials" and then ponder whether that should apply as well. I agree with you about the "arguing with stupid people" (and the drinking cheap booze part as well) and I won't do it. I have had a small handful of people stop and play 20 questions with me at events and they are doing it all to learn more about how we make things because they are doing it as a hobby and looking to start selling. When we get into the needs (items, tools, products, materials, etc.) of what is required to make it a quality item they always start to bring up the shortcuts and other "bargain" approaches and that is where I ask them, "are you planning on making a quality item or just keep making the cheap looking stuff?" and then they get quiet. Once I have their attention I then get into the economics of the whole thing and it hits them that they have no business going into business if they aren't going to do it right because our trade can be very brutal when you put out poor quality.
Now, about that Dickel. If I were in your neck of the woods I would stop by and share a bottle with you but being on the opposite side of the dirt it is quite tough. Instead, I will have one for you and you can have one for me. Sound like a plan?
I'm far from cheap. I am a member of the "he who dies with the most toys wins" club.
Now about the alcohol thing. Seems like rubbing alcohol is working fine. Picked that tidbit either here or on Cas-City. Then started to hear about denatured alcohol. Knew what it was (kinda) but had to read up on it. I am a nut on researching. Seems that it is the same stuff. Almost. But I did not care for the results of thinned dye. And I did not like to dip dye. Maybe I would like the look if I used the good stuff. Any ways, I use a piece of bath towel with a modicum of full strength dye and rub. I rub and add dye until I get a solid color without being wet.
Tennessee sour mash. Dickle is the favorite and Jack Daniels black is second. Jim Bean would be third.
And you have one of my friends close by. If you get by Mernickle Custom Holsters, say Hi to Bob and Sherrie for me.
Salud!
