Abbey is nice - I ordered some webbing samples from them (they did not even charge me shipping for it) and I will place an order soon.
But I can´t say how their thread is and don´t even know the brand.
I personally like the Amann Rasant thread very much and Amanns SERAFIL seems to be great too but never tried it.
The change of needle + thread is just a guess, I of course cannot promise that this will be the solution of your problem.
  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
For a while, about a year ago, I had a problem with the top thread moving away from the center of the upper tension disks. I ended up using a drastic fix. Normally, you feed the top thread around a triple eyelet part, then into and around the tensioners. Since this wasn't hold that particular thread down all the way, I actually fed it under the steel spring pin on the right side of the tension disks, then up on the right and over. That absolutely cured the top tension problems. I had to back off significantly to compensate for the added tension from that sharp turn.
Maybe this will help the O.P.
Other things to check are scratches on the hook and the area that is beveled behind the point. Also, make sure the hook is very tightly mounted. Any looseness can cause issues. Check for thread remnants under the hook, in the shuttle area, or even underneath.
Posted IMHO, by Wiz
Another idea is that you probably have to adjust a disc in your tension assembly just a tiny bit.
This certain disc sits between the tension spring and the tension discs. This disc has a small bar in the middle.
This little bar has to be adjusted toward the operator - maybe just a tiny tiny bit (a really tiny bit).
I have attached a picture so you know where it sits and how to put together the tension assembly.
For explanation:
There is a tension disc release pin inside your machine which pushes the lever (#223703) against the small pin (#223704) and this small pin pushes against the bar in the middle of the disc (#204271) and releases the tension discs then you lift the presser foot.
If this bar is adjusted too far towards the machine you may have a permanent disc release and so you loose the top thread tension.
To try if this is your problem just remove the disc with the bar + small pin, put spring and nut back on and adjust the top tension (it may need a bit more tension because the disc is missing) Then sew and see what happens. The only thing is that your top thread will not be released then you lift the foot.
If this solves your problem you have to adjust the small bar as mentioned above.
If not put disc + pin back and start again.
Don´t loose the small pin (#223704) which sits inside the tension assembly!
post-31854-0-38711300-1402683832_thumb.j
  • 2 months later...
Hi all,
It has been a while since I updates this thread. Two months has passed, but I wanted to make sure I fully investigated the needle and thread choices before coming to a conclusion.
So in this time I have used the standard round point Rhein Nadel needles and no-brand 20tkt (#138) thread that came with the machine from Cobra. On top of that, based on the recommendations I found on here, I have tried the following Coats threads (multiple suppliers used to eliminate bad batch):
Gral (lubricated): 20tkt
Nylbond: 20tkt (#138), 30tkt (#92) and 40tkt (#69)
Terko Satin (poly): 40tkt
I have also tried the following Schmetz needle points (each tried in 140 (22), 120 (19) and 100 (16)):
LR (reverse twist point) for decorative seams.
SD1 (small round point with triangle tip) supposed to achieve the most consistent seam appearance.
SERV 7 (LR reverse twist point) designed with a stronger, but thinner shaft in order to increase needle stability and result in greater seam reliability.
So after using every combination of the 5 thread variations against 9 needle weight and point variations I can now say with absolute confidence that the problem with the machine isn't needle or thread. The Coats and Schmetz did help a little. Seams do seem to be a little be more uniform, but we still get the stitches where the tension is out for 2-3 stitches and then back to normal again, just slightly less but not significantly.
So after about 3-4 months of trying to work out the problem with this machine I am still none the wiser really. About £240 worth of visits from machine technicians and about £80 in experimental needles and thread (types I probably won’t use in the future). It’s not the thread, needle, v belt, threading technique or the leather. Have I been unlucky and received a dud machine? It’s never been right, we’ve only ever been able to get by. It’s a constant worry as to whether I’m going to ruin a strap every time we run it. Out straps are about $20-25 a pop just in materials without factoring in time.
I’ve got to get my new strap types released before the Christmas rush. There cannot be any more delays, even if I’ve got to hand crank them. Just can’t have this machine prevent me from launching new products. I’ve had the packaging all sorted for the last 4 months and I’ve had the leather for the last 7 months. This machine has caused nothing but extra cost and delays since we’ve had it. New products are now 3 months behind and counting, and with the business only being 9 months old, this machine has been a major obstacle in our first year of operation.
I’ll give Steve a call this week and see if we can sort the machine out. I can’t say I am too optimistic at this point, I. I’ve found Steve really helpful in the past (nice bloke) and I did call him when we first had the issues with consistency but the initial recommendations didn’t work. Now that I know more about what the problem isn’t, hopefully we can get something sorted.
On another note, could anyone help me understand how to adjust the walking foot pressure on this machine? The manual with the Class 18 is completely useless and does not show the same machine in the diagrams it contains. I am getting quite bad footmarks (feed dog marks aren't a problem) on the veg tan straps we want to produce. We are going over them with the back of teaspoon and that works quite well, but I want to reduce it as much as possible at the machine to save time. Any chance the walking foot pressure could have an impact on the irregular stitch?
Anyway, please see the pics of the manual when compared to the actual machine. “adjust the pressure of the pressure ‘eoot’”
Any help will be much appreciated.
Thanks in advance to all.
It would help if I actually attached them.
For explanation:
Great suggestion. Have not tried it but I would have thought if the pin was the problem then it wouldnt a random problem but rather more of a pattern to the stitch.............
post-51892-0-30693900-1410108153_thumb.j
post-51892-0-82778300-1410108160_thumb.j
post-51892-0-64790800-1410108170_thumb.j
post-51892-0-32608800-1410108177_thumb.j
