Members benlilly1 Posted October 16, 2014 Members Report Posted October 16, 2014 Anyone have a fool proof way of setting rivets without wasting the whole bag due to bending or setting crooked?? The setter just isn't at all working well... Quote
Members TomG Posted October 16, 2014 Members Report Posted October 16, 2014 What rivets? What setter? What leather thickness? I usually struggle with Glove snaps, line 20 and 24 if the leather is not the right thickness. The posts have to be a certain length above the leather or they either will not roll (too short) or they will bend or shift (too long), which it sounds like you are getting. I think the proper length is 1/16" above the leather, if memory serves me. Use a file to cut it down if it's too long and try it. Tandy has a couple of good videos on setting various rivets. Note how he rolls the tool on some of them as he hits it. Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members chiefjason Posted October 17, 2014 Members Report Posted October 17, 2014 Sounds like the post is too long. You can cut it off if you have too. But better to get the right size to begin with. Also, try taking a couple lighter hits to the setter to get things started then increase the force. Quote
Members benlilly1 Posted October 17, 2014 Author Members Report Posted October 17, 2014 These rivets are the ones sent in a cheapo key fob kit. Some set just right but some don't. I use the hand setter with the dome end that's required for the rivets. Are there better rivets out there to buy? Quote
Tree Reaper Posted October 17, 2014 Report Posted October 17, 2014 I buy rivets from Ohio Travel. Quote
Members TheCyberwolfe Posted October 17, 2014 Members Report Posted October 17, 2014 The old coot that used to run the Oregon Leather Store in Portland was full of advice when I went buying my first tools, and he said "Ditch the rivet tool and just hammer the darn thing flat. Looks just as good on those silly Rapid Rivets and it's a heckuva lot easier.". I've been using that method ever since. I occasionally get one crooked, but mostly it works. I keep a light hand for the first hit, and then a firmer tap on the second to make sure it set. Don't smack it too hard, though, or you'll pound it TOO flat. the comments above about making sure you have the correct length are spot-on though. The Rapid Rivets will kinda 'snap' together before you set them. If it won't stay connected once you let go, the stem is too short. If you can see lots of air gap between the cap and the leather, the stem is too long. If you're out of the right length and the one you have is a tad short, one solid tap on the hole with a ball peen hammer will compress the leather long enough for you to set the rivet and it won't look too bad. Quote -- I don't suffer from insanity, I enjoy every minute! www.rogueleather.com
Chief31794 Posted October 17, 2014 Report Posted October 17, 2014 Many years ago I bought the Tandy setter with all the dies for snaps, rivets, etc. It has never failed to set anything perfectly in over 5 years, maybe longer. They are costly, but I was occasionally ruining projects, and that is more costly than the tool. Chief Quote "Life's too short to carry ugly leather"
Tree Reaper Posted October 17, 2014 Report Posted October 17, 2014 I bought one of those as well from Tandy ,it's well made but I wouldn't buy the same one again because you can't get all the dies you need. Quote
Members RiverCity Posted October 18, 2014 Members Report Posted October 18, 2014 First as others have mentioned, make sure the post is the correct length to begin with. Typically youll see rivets in 2mm increments. I find the 9mm is right for two layers of 8-9, even 9-10 but thats pushing it. 7mm for two layers of 6-7, 5mm for two layers of 4-5 etc. Also it should be noted that the holes for the rivets be tight, the rivets should "pop" into the leather and be tight enough to hold themselves in there. The rivet on the right is about how much exposed post you should be seeing. All setters are not created equal either, the Tandy setter is ok at best, but its not domed good enough IMO. I use a setter from a pack of various setters available from Springfield Leather for under 10 bucks, and I modified it and polished it to make it better. The Springfield tool is longer and a larger diameter. Makes it easier to handle and use. I put mine in a drill press and sanded/shaped the dome to make it even bigger and smoother, the polished it with Flitz. A was just hammered flat, but I find the look bad, and if it fails the top part of the cap typically falls off. B was set with Tandys tool, and while it does an ok job, if you are off centered at all the cap will be dented, and the post can bend. C was set with the modified tool, it sets deep, but does not bend the post. It also leaves a nicer dome to the rivet. I set a lot of these rivets. Every case I make has just shy of 100 each, and I have torture tested them. If they are set correctly, the leather will tear out or the rivet will literally tear around the base of it before it seperates. Hope this helps! Chuck Quote
Members billybopp Posted October 18, 2014 Members Report Posted October 18, 2014 If you like the idea of a bench setter, but not Tandy's price ... Folks seem to have good luck with this less expensive alternative: http://leatherworker.net/forum/index.php?showtopic=51602&hl=%2Bgoldstar+%2Brivet#entry329128 I bought a Tandy before I saw the above, so spent more than I might have ... And wouldn't set rivets any other way unless I absolutely had to. Hope that helps Bill Quote
