I read through a few general leather working books and haven't come across any instructions on how to find the gusset length on bags with emphasized rounded corners. Most bags don't have too much of a rounded corners, on some bags the corners round off more and cause the gusset to become longer. Both the curve of the corner and thickness of the leather make it difficult to find out the correct length of the gusset for a proper fit.
The way I find works is to figure out the length and height of the bag first. In a 90 degree corner bag with a gusset, you would calculate the gusset by length + double the height. With the emphasized curved gusset bag the length would be a little bit shorter.
In a square corner bag with height of 20 cm and length of 30 cm the gusset will be
Length + Height + Height = 70cm gusset length. Give or take a few mm for thicker leather
A corner radius of 5 cm diameter for the curved corner bag with the same dimensions height 20cm, length 30cm. To find the length of the gusset:
Length - double the diameter of the corner radius + height + height + (diameter X 3.14 then divided the total by 2) = length of gusset.
30cm - 10cm + 17.5cm + 17.5cm + (5 X 3.14 divided by 2) = 67.85 cm
To take it a step further to include the added length to the gusset by using 9 ounce leather:
Thickness of leather X 3.14 divided by 2
3.6mm X 3.14 divided by 2 = .6cm
If you choose to keep using the same radius curve but different lengths: 10 cm diameter:
subtract double the diameter + (3.14 X diameter divide by 2)
-10 - 10 + (3.14 X 10 divided by 2) = -4.3cm off the length
Gusset length.pdf
good lord
Lol!
Seriously man... enough with the math. It's not complicated... just make it double height+width, attach and cut off the excess.
I get what your saying. Its a bit complex, however I'm pretty positive a 5th grader can do it. If you do the calculations wrong the bag would be scrapped. When your dealing with something that isn't a square gusset its not as easy as length + double height. You also have to account for thickness of leather and the curve (could be 10cm diameter radius curve or 2 cm diam. radius curve, both will have different lengths)
One calculation with math then one more time by physically doing it by hand. It shouldn't take more than 30 seconds to do a calculation, for a pattern you can use as long as you like. In my opinion leather working is an all around effort of designing, pattern making and actually making the product as close to the design as possible.
Aw man... you're really over-thinking it. I make all my bags with a rounded corner as it's easier to sew up. I just do the even simpler 2nd grade math of doubling the height and adding the width, then add an inch or so for a slight bit at the end. Attach, cut off the extra, sew.
EDIT: If you really want to know the exact length you need, use a tailor's tape. This isn't rocket surgery here. ;-)
Edited by AndyL1
Provided that the sides and bottom are perpendicular, the rounded portion will always be 90deg (1/4 of a circle ) hence the length around it will always be 1/4 of the circumference of said circle.
Where h = Side height
w = width of bottom
r = radius of curve
total length of the perimeter will be:
2(h-r) + (w-2r) + 2(pi*r*2*0.25) = total length
Simplified: 2(h-r) + (w-2r) + (pi*r) = total length
In your example: 2(20-2.5)+(30-2*2.5)+(3.15*2.5) = 67.85
That said, in my experience even the best measured gusset is never exactly right after cutting, dying, shrinking, stretching, stitching .. Any and all of which can cause the dimensions to change slightly. According to Murphy's law, this change will ALWAYS be on the side of too damned short rather than a little long. So just cut the thing a little longer than you need and trim it in place for best results.
Bill
Bingo. A little dampness and minor adjustments can alter a messenger bag seam as much as 1/4" each direction depending on the leather you're using. If you can't use that to your advantage, all the math in the world isn't going to help you. If you know and can use that, 10th grade math is unneeded.
I make a paper prototype and take rough measurements to get the gusset length. I then make a full leather prototype carefully noting how short or long I was off, 9 times out of 10 - the prototype is fixable or close enough anyway. Keep notes, and by the 3rd bag, the length is close to perfect.
How do you fix a gusset at the wrong length?
  • line up center lines and mold into place.
  • If too long, either cut off the ends evenly and re-burnish, or adjust the gusset so it sits proud of the surface all around. 1/8" can net you over 1/4"at each end.
  • if too short, line up the ends and cut the corners increasing the radius, or set the gusset back from the face.
  • Glue into place, trim, and sew together.
Edited by BAD HIDE
  • 2 years later...
Gusset length.pdf
This was very helpful. I sew my pockets onto the gusset before I sew the sides and this calculation helped me get an initial length that was nearly perfect. I used the calculation, cut the piece, and then fit it to assure all was right.  Fit perfect. The method of cutting the gusset long and cutting off the extra after sewing works fine if you aren't attaching something like a pocket to each side that need to be in the same place on each side.
Thanks,
Kyle
I draw the pattern and then use a flexible staedler  drawing curve. Lay it on the pattern following the corner curve on the stitch line and mark the ends. The length of the curve straightened is the distance between marks on the pattern. Leather thickness matters a lot less than the offset due to stitch allowance with regards to gusset length due to the stitch line being shorter than outside of pattern. Measuring the stitch line not the cut line eliminates this.
  • 7 years later...
Thanks,
Kyle
surely if you line up the centre marks you can still place your pockets and then still cut the ends shorter if needed?
Similar to TinkerTailor, I do not make the edge length equal, make the stitch lengths equal.  One way to do this is count the stitch holes on the front and then make an equal number of holes on the gusset.
I use CAD software that calculates the stitch length for me but you can do this on a calculator, or measure the stitch length off a pattern.
If hand stitching, counting the holes on each piece will work perfectly. If machining however, there is the possibility of stretching the gusset depending on the severity of the curve. If doing a repeat pattern where the length of the gusset is already known, stretching is still possible and I would advise sewing from each end so any stretch will be worked out in the middle.
I've never made a gusset yet, but all the professionals on youtube I noticed cuts their gusset 1" shorter than the body it's being sewn to.
At some point I'm going to try it.
You can't generalise like that about gussets. Sometimes a "gusset" will go down either side of a bag, sometimes it will go down one side, across the bottom and up the other side or down the front across the bottom and up the other side depending on what you're calling the front. If there are curves involved the thickness of the leather will be a factor.
I'd be very wary about cutting a gusset short. If in doubt leave it long and cut afterward. I think the safest way is to use basting tape all around the perimeter, stick your gusset and cut to length but if I'm machine sewing I'll still start at each end toward the middle.
Yes, that works for laced bags as well. I am working on reproducing a 1970s Tandy pattern and that is how I made the gusset and it fits well.
@toxo is right about that. Stitch length, not edge length, is the more important measure (although the couple gusseted bags I have made were close enough on both measurements that I was able to cut my gussets the same edge length and then do only minimal trimming). I’ll add that the details of the construction make a difference as well. Whether the gusset is curved or straight, darted or flat, molded outward as is done with veg tan bags sometimes, or a soft oil tan makes a big difference. So does whether the bag will be turned out after construction (like I had to contend with when making a bottom gusset tote bag for my mom).
Lots of measurements and geometry are one’s best friends here.
Thanks for the tips & tricks mentioned. No a few youtubers that produce some nice products. They just mentioned that if doing a backpack or bag with a center/U gusset & using 6-7oz leather that cutting them a inch shorter than the body its sewn to usually works out perfect everytime.
This is the only reason I mentioned it. I was going to try & design a small handbag or something & try it for myself to see how it comes out.
Not a bad rule of thumb, as long as it’s used as such and not as a set rule. But it sounds like you’ve got that straight in your own head.
I figure I might as well try the method out & see if it holds true for me. But the other way i look at it is, the only way to learn is by doing it  & getting the practice while doing it.
If i was to design a bag or case & it needs a gusset & the project will allow you to leave the gusset long & then trim after. I'm definitely going that route.
A bag of some sort is my next leather project I want to try my hand at & possibly learn a thing or 2.
Reason I joined because of all the great people on this forum willing to help. It's a great community!
