Members Ta2ooz Posted March 14, 2015 Members Report Posted March 14, 2015 Thanks yet again Tboyce. I cannot express the amount of appreciation I have for doing this. Quote Etsy shop https://www.etsy.com/shop/Ta2Leatherworks
Members maddhatter Posted March 15, 2015 Members Report Posted March 15, 2015 thanks tom as always your patterns rock !!!! and help us out alot. looking forward to more awesome patterns. thanks. Quote
Jimmy McLaughlin Posted August 26, 2017 Report Posted August 26, 2017 Thank you for the pattern.I'm not able to print that size. If I take my printed version to staples, can they enlarge it? Quote
Northmount Posted August 27, 2017 Report Posted August 27, 2017 6 hours ago, Jimmy McLaughlin said: Thank you for the pattern.I'm not able to print that size. If I take my printed version to staples, can they enlarge it? Your PDF viewer should have some options in the print dialog box. Depending on your viewer, it could be under "zoom" or "print handling" or similar description. Select tile pages or split pages to multiple sheets. It will split the drawing up into multiple sheets, you trim and tape them together. Print at 100% scale. Play with it a bit and you will find the right settings for printing tiled images. Tom Quote
Rockoboy Posted August 27, 2017 Report Posted August 27, 2017 Thank you very much for posting your patterns. I am hoping to try out a few different techniques, machine sewing v's hand sewing, lined v's unlined, different dying and edging finishes. I printed these patterns out on A3 paper at 100%. Does that mean they are the size that the leather needs to be? The patterns look enormous. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Northmount Posted August 27, 2017 Report Posted August 27, 2017 4 hours ago, Rockoboy said: Thank you very much for posting your patterns. I am hoping to try out a few different techniques, machine sewing v's hand sewing, lined v's unlined, different dying and edging finishes. I printed these patterns out on A3 paper at 100%. Does that mean they are the size that the leather needs to be? The patterns look enormous. Using Adobe's measure function, the widest part of the pattern is about 8.75 inches. Check your printout and see if it matches. Tom Quote
Rockoboy Posted August 27, 2017 Report Posted August 27, 2017 The widest part of the regular sized pattern is 229mm (9.012") long by 221mm (8.708") wide. The larger case is 262mm (10.315") long by 255mm (10.039") wide. Maybe I can use some thin cardboard (cereal packet stuff) to make a test piece. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Northmount Posted August 27, 2017 Report Posted August 27, 2017 5 hours ago, Rockoboy said: The widest part of the regular sized pattern is 229mm (9.012") long by 221mm (8.708") wide. The larger case is 262mm (10.315") long by 255mm (10.039") wide. Maybe I can use some thin cardboard (cereal packet stuff) to make a test piece. Definitely. I like to tryout patterns or make new patterns using paper or light weight cardboard. I staple the edges together to check shape and fit. Adjust as necessary, then go for the leather. Sometimes will do a second prototype on cheap leather to see how it really turns out. Tom Quote
Members madam Posted December 25, 2017 Members Report Posted December 25, 2017 Thanks for the larger pattern Quote
