Members b2k Posted February 11, 2015 Author Members Report Posted February 11, 2015 Cleaned, tested, max stitch lenght of about 3mm. I'm planning to disassemble, clean the gears, and idenrify worn parts. Any tips or pitfalls I should be aware of? Quote http://www.facebook.com/scallywagleather
Members Constabulary Posted February 11, 2015 Members Report Posted February 11, 2015 3mm is not very much!!!! Id´first clean it thoroughly and then test again but don´t expect too much progression from just cleaning it but you should do it anyway. I just have posted a download link for a service manual + parts list of the 29K71 in this thread: http://leatherworker.net/forum/index.php?showtopic=57862&p=398341 It will be very helpful for you I think! I recently have restored an older model of the 29K (much much older than yours) and I got longer stitches by replacing this part: https://www.college-sewing.co.uk/82167-FEED-MOTION-BELL-CRANK-LEVER-SINGER-29K I would assume that when you replace the above part and this part here: https://www.college-sewing.co.uk/82053-FEED-MOTION-RING-SLIDE-BAR-SINGER-29K you get a much better result. But I can´t tell you how much longer the stitches will be. But these two parts are responsible for the stitch length. Considering the "relatively low price" you have paid (in Australia people have to pay approx. 3 times the price you paid if I´m right) I think it is worth the investment. This is at least what I would do. Maybe someone else has an additional tip for you. The 29K´s are very simple machines, there is not much that can go wrong. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted February 11, 2015 Members Report Posted February 11, 2015 BTW - I guess you know how to adjust the stitch length at your machine, right? You should have it set at to the max. stitch length of 5 SPI (Stitches per Inch) then measure again. The manual I have linked will give you good instructions. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members b2k Posted February 11, 2015 Author Members Report Posted February 11, 2015 For cleaning I'm thinking to use nitro solvent, since many parts are really gunked up. Or it's better to use something else? Very nice manual by the way, will be very useful, many thanks! Quote http://www.facebook.com/scallywagleather
Members catskin Posted February 12, 2015 Members Report Posted February 12, 2015 Buying new cheap parts is not always the best choice to fix stitch length. On my 29k51 I used a spot of brass on the one piece and filed it to fit the groove in the other one and now get longer stitches then they claim on here to be possible. It seems that the parts made now just are not made to the close fit you can get by hand fitting. And with the right needle plate and needle you should be able to use up to 207 thread. I have been for 25 years. In mine I never use thinner then 138, you can, but I have never needed thread that thin. Quote
Members Constabulary Posted February 12, 2015 Members Report Posted February 12, 2015 I also run 138 tread in my 29K71 - always! The needle plates are often marked with 23 for coarse needles. So 138 is no big deal and 207 thread seems to be possible but I never tried it. Due to the tiny bobbing you will not get much of the ticker thread on it but when you use the machine for repair work it should work. I always use some sort of Nitro solution for cleaning the old gunk but you have to be careful on the outside. But usually the old paints are very tough and withstand a short contact with Nitro solution w/o problem. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members b2k Posted May 26, 2016 Author Members Report Posted May 26, 2016 A bit of thread necromancy here: I have had the machine cleaned up and tuned by a service shop, for the moderate price of 65 euros. Now, with thinner thread it works great, but as soon as Itried using a thicker one it starts skipping stitches, sometimes on in 20, sometimesa five in a row. Also it appears that the needle can't always pick up the thread from under the plate when threading the machine, sometimes it picks the thread, sometimes after a couple of tries, other times I have to manually put the bobbin thread up trough the plate hole. The thread is around 0,8 millimiters thick, not quite a millimeter and more than half. It is a polyester bonded thread. Any tips? Also, how thick is thread #138? and with wich needle it should go? Quote http://www.facebook.com/scallywagleather
Moderator Wizcrafts Posted May 26, 2016 Moderator Report Posted May 26, 2016 1 hour ago, b2k said: A bit of thread necromancy here: I have had the machine cleaned up and tuned by a service shop, for the moderate price of 65 euros. Now, with thinner thread it works great, but as soon as Itried using a thicker one it starts skipping stitches, sometimes on in 20, sometimesa five in a row. Also it appears that the needle can't always pick up the thread from under the plate when threading the machine, sometimes it picks the thread, sometimes after a couple of tries, other times I have to manually put the bobbin thread up trough the plate hole. The thread is around 0,8 millimiters thick, not quite a millimeter and more than half. It is a polyester bonded thread. Any tips?Also, how thick is thread #138? and with wich needle it should go? According to the needle and thread chart on the Toledo Industrial Sewing Machines website, #138 bonded thread is: .0163" (.414mm) That is the maximum size thread for your patch machine, although it is foolish to load heavy thread like this in a tiny bobbin. It requires either a #22 or #23 needle. I have the same machine in my shop and limit it to #69 bonded thread. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members cdthayer Posted May 26, 2016 Members Report Posted May 26, 2016 (edited) On my Singer 29K70 machines, I always put the thread up through the needle plate hole by hand as I pivot the NP back into place. Avoids getting a trapped thread tail, or it being out of place [for the hook to catch it]. Edit: (Should have said "for the top thread to bring it up cleanly.) CD in Oklahoma Edited May 26, 2016 by cdthayer Wrong wording.... Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
