That tool from elfitakorea is very interesting but it would only work for small objects. I live in an appartement and what I do is as someone said above, not to use the maule before 11:00am and not after 19:00pm.
I don't use granit but a block of hard plastic that I put on my legs when seated to hammer. Also I have found that depending on where I am seated in the room the noise change a bit, same thing with the angle the maule hit the tool you're using.
Sometimes I put all my stuff into a bag and I go outside and sit on a bench to hammer, then I come back home to stitch.
I have seen these at leather shows and they are much quieter than a manual hammer.
I also recommend a 2 ton arbor press for all 3D stamps and lettering, etc and a rivet press for snaps, rivets etc.
Last resort:
Image result for vicious dogs
That should keep the complaints to a minimum
Edited by BDAZ
Last resort:
Ooo this looks interesting! I already own a foredom for silverworking, one of its heads is a hammer attachment for setting stones, this is a similar set up. Looks good!
