Members yldbill Posted April 29, 2015 Members Report Posted April 29, 2015 I am in the process of designing my first CCW gun belt and all the info says to get a double thickness belt for full size weapons. My question is,where do you end the double thickness at up near the buckle end? I can't imagine bending double thick leather around the center bar on a buckle. I am planning on using 2 layers of 8/9 oz leather,is that about normal for 2x thickness? Quote
Chief31794 Posted April 29, 2015 Report Posted April 29, 2015 (edited) I may catch some flack but I don't normally make mine "Double" thickness. I make them two ways, one is I use a normal thickness cut from a belt bend which is normally 9/10 oz and then laminate a 4/5 ounce to that, I then skive the end just as I would a single layer belt before I stitch the belt or I laminate two 6/7 oz strips, when I do that I stop the second layer at the same place I would normally skive then feather it with a hand skiver. I don't have a preference both are very strong and very durable and look about the same once they are glued and sewn. Chief Edited April 29, 2015 by Chief31794 Quote "Life's too short to carry ugly leather"
Thor Posted April 29, 2015 Report Posted April 29, 2015 It may sound like a dumb question, but isn't 16 oz. and 18 oz. even a bit overkill for a gun belt? Shouldn't 10 to 13 oz. be sufficient? Quote
Chief31794 Posted April 29, 2015 Report Posted April 29, 2015 It may sound like a dumb question, but isn't 16 oz. and 18 oz. even a bit overkill for a gun belt? Shouldn't 10 to 13 oz. be sufficient? I wear a Glock 19 every day on a single ply belt, the belt is about 6 years old and doesn't give or show signs of wear. So my answer is yes a normal belt is plenty, however, a lot of customers are convinced they need the extra heft, so I sell it to them. I never argue. If it were a Ruger .44 Mag with 10-1/2" barrel then maybe you would need something more, but who'd want to wear that "Hawg" every day or any day. Many customers think that a double belt should only cost twice as much, nope!!! You got gluing, sewing, not to mention when I do them, the bottom blank is 2" which I contact cement to the 1-1/2" blank then trim to width. Personally, I don't like the feel of the laminated belts, they are too stiff and bulky for my taste. I think the idea behind the double belt comes from customers buying a 1911 or such, putting the holster on a Walmart Belt then when it wears out in about 10 minutes (just an estimate), they are convinced they need double to prevent that. That's just my opinion, I could be wrong, that happens a lot more lately. Chief Quote "Life's too short to carry ugly leather"
Members Dwight Posted April 29, 2015 Members Report Posted April 29, 2015 (edited) I make, sell, and wear a double belt. I usually make them of blanks cut from the same hide, . . . generally cut side by side. The better looking of the two becomes the outside, . . . which will wrap around and through the buckle, . . . come back and fasten to itself, . . . and lay flat next to the inside piece. I use good quality buckles, . . . and I Chicago screw them together. None of my belts has ever been returned as being worn out. Comfort is in the waistline of the wearer, . . . and while in the pulpit on Sunday morning extolling the virtues of Jesus Christ, . . . it sometimes is a bit more comfortable to have my thinner Ranger belt on, . . . but I also do not have my 1911, and two 8 round magazines hanging off it. Sometimes, I will use one thicker piece and a thinner piece as Chief said he does, . . . but usually mine come from a 7 oz piece of leather. It is (if right on the money) .109 thickness which will result in a .218 thickness belt. The one I currently wear is right at .240 and is a little stiff, . . . but I personally like it better that way. The ones I make and sell will generally start at .180 overall thickness for a slim, ladies belt, . . . to the .250 for Mr. Big Guy whose girth is substantial. And, . . . yes, . . . a few thousandths of an inch WILL make a substantial difference in the comfort level it gives. There is no "one size fits all" in this question, . . . I hope this helps you, . . . may God bless, Dwight Edited April 29, 2015 by Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Chain Posted April 29, 2015 Members Report Posted April 29, 2015 I remember reading somewhere that Peter Main also adds a strip of filament tape between the layers for strength on his belts, or maybe it was to stop wrinkling. Either way it can't hurt Quote
Members Dwight Posted April 30, 2015 Members Report Posted April 30, 2015 I remember reading somewhere that Peter Main also adds a strip of filament tape between the layers for strength on his belts, or maybe it was to stop wrinkling. Either way it can't hurt Actually, . . . it can hurt. First off, . . . the belts won't wrinkle unless the maker does some radically wrong things, . . . and secondly, . . . the contact cement will not adhere to the filament tape as well as the leather, . . . it can come loose, . . . leaving only the stitching holding it together, . . . I prefer mine to stay "together" as long as it is a belt, . . . so I don't put any foreign object in my leather belts, . . . other than the metal and stitching. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members klaykrusher Posted May 2, 2015 Members Report Posted May 2, 2015 I run the inside piece right up to the beginning of the slot for the buckle prong. Quote ~Dave
