I don't have a multistep approach to punches.
I just keep my punches sharp, and place the leather on top of something firm but wont damage the punch. One good whack, and I get clean punched holes every time. On thick leather, I poke the punch into a slab of beeswax to prevent it from getting stuck.
  • 2 years later...
I always see the hole slit on the side that the stud will be pulled into by tension, but this seems like it will cause a tear or increase in hole size over time. Instead, why not put the the slit on the opposite side of the tension? That way the force is on the hole instead of the slit. I assume there is wisdom in the traditional method, but I wonder if anyone has considered an alternative direction for the slit.
No, the hole does not open up larger; Under the ball head is a bar stem, the leather bears against that bar thus the sides of the hole are in compression. Leather under compression does not enlarge or rip, it is quite a solid wall. If you have the access slit on that side you risk having the slit widen out and riding over the ball head thus having the closure open up when you most need it to be secure. Also a slit cut will rip though much more easily and faster than a circular hole. In many manufacturing processes the way to end a straight slit cut so that it doesn't extend when not required to do so is to end the slit with a circular hole or end
Military holsters from as far back as the 1840s used this form of closure and after many years of use the hole is still a tight fit over the ball and stem
In English work that is the traditional way to do it. Pictured is an old pippin punch by James Dixon. I don't know if these are/were sold in different sizes but this one measures 1/8" diameter but with a 5/8" tail, which really helps the flexibility -- even in stiff 4mm/10oz bridle leather. Perhaps this is the source of the difficulty with even very good leather cracking -- too short a slit?
That's true, a longer slit may help, but have you ever tried putting the slit on the opposite side like in the my picture with the red line?
Edited by doorty
It may be your wording perhaps, but normally the stud stem does press into the hole and not the slit, contrary to what you have said above. In the picture of the bag you have shown if you were to pull on the strap it would be stopped by the hole and not the slit and is therefore correct. Have any pictures that show it the other way?
YouTube Channel
Instagram
Ah, I missed the little red line.
Yes I've tried it, before I got the proper punch and had to use a normal round punch and cut the slit with a knife. I got it the wrong way round a few times, and it certainly is the wrong way round. If you put the tension on the slit you're relying on the stiffness of the leather to keep the tension in the strap. As soon as the leather starts to squash the stud will start to move into the slit, which loses tension on the strap and as the stud moves up into the strap that's when the slit will start to tear.  It gets very easy for the strap to pop off the stud too.
By putting it the traditional way round, with the tension bearing on the hole, the pressure is spread over a wider area of leather that doesn't move away from the stud as it would at the slit.
