Members SouthernCross Posted January 13, 2016 Members Report Posted January 13, 2016 I've been playing around with making some minimalist wallets and I've been trying to dye them with Fiebings cut with denatured alchohol. Of course, when I come back the next day the pieces are stiff as heck and I can't really bend them into shape without cracking the leather. Should I case the leather and bend it into the shape I want first, then dye it? Quote
Members Dwight Posted January 13, 2016 Members Report Posted January 13, 2016 That'll usually work, . . . or, . . . depending on how you plan on finishing the wallet, . . . if you plan on adding any oil, . . . this is a good itme & place to do it, . . . let it set for a day, . . . work it slowly, . . . I've also done it with other final finishes, . . . used them to dampen the leather, . . . bend it, . . . the do a nice final on the areas I handled in the bending routine. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Bolt Vanderhuge Posted January 13, 2016 Members Report Posted January 13, 2016 There are many more experienced members that may have a better solution but I would rub in a light amount of neats foot oil. It will soften it back up. I have found, that instead of cutting the Fiebings with DA, if I completely wet the leather and give it a few minutes for the water to migrate thru all the fibers then dip dye in non cut dye, the color stays lighter and colors perfectly even while the leather stays soft. I only dip for a few seconds and then pat the leather with a paper towel to get any excess off. At the end of the leather drying I will rub the item with a soft cloth and I get no to almost no rub off. Quote
Members Tugadude Posted January 13, 2016 Members Report Posted January 13, 2016 You might try carauba cream after it dries. Works good for me. Quote
Members SouthernCross Posted January 13, 2016 Author Members Report Posted January 13, 2016 Thanks a bunch for the suggestions, gentlemen. Quote
Members snubbyfan Posted January 14, 2016 Members Report Posted January 14, 2016 The dye's drying the leather. Neatsfoot'll put the moisture back. Just rub some on and let it sit for a while. Quote Keep on Chooglin'Check out my YouTube Channel, comment and subscribe for updateshttps://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
Members venator Posted January 18, 2016 Members Report Posted January 18, 2016 Unfortunately the neatsfoot darkens the leather and it's ruined a few of my projects that way. Quote
