I was wondering if anyone has any advice on a good, yet inexpensive for backing or lining belts. I want to step up my game a little and start using something because I always just leave them bare.any help would be greatly appreciated, thanks
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
If you make the belt out of two equal thicknesses of veggie tanned leather, . . . contact cemented together, . . . sew the edges, . . . you will have a belt you can will down to your grandchild possibly.
They are absolutely sturdy, . . . strong, . . . look great, . . . wear great, . . . and if you carry "stuff" (cell phone, . . . handcuffs, . . . CCW, . . . pager, . . . ammunition, . . . flashlight, . . . etc) on it, . . . it won't sag.
If you use almost anything else, . . . the edges will not burnish really well together, . . . wind up looking raggedy in a couple years or so, maybe even sooner.
May God bless,
Dwight
www.dwightsgunleather.com
Personally I use two layers of vegetan back to back as suggested above, it allows for dying and durability as well as snazzy edges. Contact cement, sew and it's solid.
In my first and only belt project, I used a belt blank from Tandy (8-9 oz). After that was tooled & dyed, I lined it with 2-3oz veg tan. The result was a nice, stiff belt that wasn't too thick with edges that burnished easily.
Hand stitching that thing took forever (about 4-5 hours). I need to lose weight to make my belt projects smaller :spoton:
Edited by byggyns
I line mine with a 2-3oz Horween Double Horse Front......
I don't have a sewing machine and I never lined a belt. My question is, after you cut a glue you're lining, do you put a stich line and use a stich spacing wheel or do you use a punch? If using a punch do you go through both sides or one side and use an awl ? Go easy on me folks, I am new to this.
Jim
I think a wheel, stitching chisel or pricking iron would be fine to mark your holes. You can then use your all to make the holes one by one as you sew - if that's what you want to do.
Now you can use a stitching chisel to punch your holes too. But I would caution you on that. Usually this is fine, but you have to do it right. Sometimes using a stitching chisel this way can cause your two layers to de-laminate and you'll have to try to re-glue that area and it sucks. The factors that increase the risk of that are,not having a solid base under your piece, a poor glue/cement job, using a really wide chisel (lots of teeth) and using a tool that is not sharp enough.
May God bless,
Dwight
Dwight
Hope Im not hijacking this thread
is there a specific reason to use two equal thicknesses as opposed to using a heavier weight on the exterior and a lighter weight on the interior?
