Last weekend I found this 29K (built in 1905) and figured the tag says 29 K.S.V 3 - so obviously a Special Version (or variant) of the 29K cobbler machine.
The only obvious difference compared with a 29K3 is that the 29K S.V. 3 has two threaded holes in the lower arm. This most likely is for attaching a binder attachment. I have no proof for this but I guess the threads are for a binder attachment.
I just wanted to share some pictures because there are not many of them around and even on Needlebar.org or ISMACS I wasn't able to find further information.
IMG_3324.thumb.JPG.77163d513b54ab057c330
IMG_3314.thumb.JPG.3d0cdc42f0ea6d019e270
IMG_3316.thumb.JPG.634fa003978a1719ef261
IMG_3317.thumb.JPG.58341b2b3374fb092af3f
IMG_3318.thumb.JPG.f6a58a2f2f5c6b787f8b6
IMG_3320.thumb.JPG.2af913d67360771a00591
Edited by Constabulary
Thank you..
That brings a smile to the morning.. Compared with my recently aquired ( waiting for restoration ) 29K51* ( built 1928 ) and which was the only machine of a Breton cobbler ( I bought it from his family, straight out of his tiny workshop )..I'm curious, what is the flat bar and wing-nut assembly that runs at the back from the middle of the arm to the needle "gubbins" for ?
*Bought as a result of seeing your posts and reading your "sig"..
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
The flat bar & wing nut is how they get the pressure foot pressure on these older models,your 28K51 has the different newer style coil spring.
Constabulary,I do see a adjusting screw on the take up lever that none of the 29-3&4 usually have maybe this is why it's a SV?Of course it could of been added through the years as a replacement part too.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Bob, I think you mean the small screw on the backside down left of the foot lifting lever, right? That screw is holding a spring that pushes against the foot lifting lever to hold it in place. You have to push down the lever to lift the foot. I have seen that on other 29K1, 29K3 and 29K4 as well.
I think Bob is referring to the screw sticking out of the barrel adjuster on the backside of the take-up lever. It wasn't there on any 29-4 I have owned. It came along in later generations and adds forced lift to the take-up.
Posted IMHO, by Wiz
Hi Folker, do you mean the braid holder?? i think the braid holder #81912 with the two braid bobbins #81909 was clamped on with a bent pin and thumb nut #287d and #81913 according to the parts list? the binders on these machines look as if the are no bigger than the needle plate. #85675 would probably go right in front of the needle on the combined feed dog and needle plate #81933 or #81925?? just a thought? it could have been for a material gude of some kind??
I always have 29K on mind and don`t even think of the 29 w/o the K suffix - sorry! That screw (thread take up adjuster) is pretty common - at least over here. Not sure when they have introduced it. I think the very early 29 and / or 29K came w/o this screw.
Is that long flat bar "spring steel" ? That would fit in with what I take Bob to be talking about..( and would make sense re the "difference" Bob mentioned, between Constabulary's machine and my 29K51 re foot pressure )..Looks like it can slide through the fitting where the wing nut is..and that the amount of "spring" can be adjusted by the large thumbscrew ( near the "pivot" ) in the middle of the top arm casting..
The "bar" is spring steel and the earlier 29 / 29K all have them. I 'm sure Bob knows this type of spring very well. All ADLER class 30 patchers up to to current day have them. BTW - Adler class 30 and singer 29 / 29K are using the same spring - it is interchangeable. The 29K51 is the first one with helical spring. So all Singer patchers from 29K51 onward have this helical / coil spring and the earlier models have the blade spring.
I have stolen this comparison chart from needlebar.org - see attachment.
singer 29K class comparisons v02.pdf
Thanks :) That is really useful..as are the pictures of the back of the machine..Here in France there is a sort of "Craigslist".it's name is "le Bon Coin" ( Translates to "the good corner" ) ..no-one ever shows the back of the machines in the adverts, ( and most of the pictures of the industrial machines for sale are taken to include the entire stand, so you can't make out any detail of the head part above the stand, and are often blurry ) and frequently they don't give the model type, nor any details such as close-ups of the presser feet and needle areas..
The more I learn about machines from people here, the more fascinating I find them and the whole subject of the effects and influences of sewing machines on and in society and history..:)
Edited by mikesc
