Members msdeluca Posted June 11, 2016 Members Report Posted June 11, 2016 (edited) CB3200 Machine Labels - Cheat Sheets Now that I am old, it has become easier and easier to forget some of my machine settings between uses. I find myself wasting time looking things up that I should remember and I don't see the situation getting any better. I created these labels from the Cowboy CB3200 manual, tips I have learned over time on setting thread tension, and some needle/thread/thickness recommendations from WizCrafts over at leatherworker.net, printed them on a clear inkjet label sheet, and affixed them to my machine. Now all of the information needed to match the needle and thread to the material thickness, to determine which direction in which to insert and thread the needle and bobbin, and to adjust the tension is right on the sewing machine. Following are a couple of pictures of the labels on the machine and here is a pdf file of the labels that you can download and use to print your own. Hope this helps. Michael Edited June 11, 2016 by msdeluca Correction Quote Michael www.conceptleather.blogspot.com www.temptedthreads@blogspot.com
Hockeymender Posted June 11, 2016 Report Posted June 11, 2016 I too think that's a great idea! Quote Regards, Joe Esposito www.hockeymenders.com instragram: @hockeymenders.com
Uwe Posted June 11, 2016 Report Posted June 11, 2016 (edited) Nice work! I'm a big fan of putting instructions and information right where you need it. My label maker gets lots of use. One of the first things I do when I start working on a new machine is make a needle system and size range label and stick it on the machine. The other thing I often need a reminder of is which way to insert the bobbin. I made a graphic and lasered it right on the inside of my bobbin cover of my Adler 205 (a clear sticker would work just as well in that spot, but I have access to a CNC laser and I really wanted to try out the metal marking fluid). I think I'll start lasering bobbin threading graphics onto the hook slide cover plates of my flatbed machines. The advantage of laser etching bare metal is that it doesn't wear off. Edited June 11, 2016 by Uwe Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
mikesc Posted June 11, 2016 Report Posted June 11, 2016 (edited) Uwe, my innner nerd is in awe :)..Now I have the perfect reason to give my wife as to why I need to buy a laser..( raises glass ) ..cool. Edited June 11, 2016 by mikesc Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members msdeluca Posted June 11, 2016 Author Members Report Posted June 11, 2016 3 hours ago, Uwe said: Nice work! I'm a big fan of putting instructions and information right where you need it. My label maker gets lots of use. One of the first things I do when I start working on a new machine is make a needle system and size range label and stick it on the machine. The other thing I often need a reminder of is which way to insert the bobbin. I made a graphic and lasered it right on the inside of my bobbin cover of my Adler 205 (a clear sticker would work just as well in that spot, but I have access to a CNC laser and I really wanted to try out the metal marking fluid). I think I'll start lasering bobbin threading graphics onto the hook slide cover plates of my flatbed machines. The advantage of laser etching bare metal is that it doesn't wear off. Very cool, Uwe! Quote Michael www.conceptleather.blogspot.com www.temptedthreads@blogspot.com
MADMAX22 Posted June 12, 2016 Report Posted June 12, 2016 Uwe that is great. I think any industrial machine should come with the bare essentials labeled on them, like the old school lathes. Ofcourse the new ones your on the computer so it doesnt really matter anymore. Quote
Members billybopp Posted June 12, 2016 Members Report Posted June 12, 2016 I'm pretty sure that all such labels that used to be on machines from the factory have been crowded out by the ones that the lawyers make them put on. You know the kind "Stop machine before changing needle". " Do not put fingers beneath needle while sewing". "Machine will not sew without thread". " Thread must be purchased separately". "Power must be on before operating". But seriously ... GREAT idea for these labels! Bil Quote
Members brmax Posted June 12, 2016 Members Report Posted June 12, 2016 Michael, excellent idea there thanks for the tip. Uwe, the tools you come up with amazes me. good work Bill I have to say this early morn that comment gets the chuckle and will last the day. time for some coffee it should be ready now Thanks Floyd Quote
Members Romar Posted June 20 Members Report Posted June 20 Wow, this thread really hit home for me. I’ve been sewing for years, and I can’t tell you how many times I’ve sat down at my machine and completely blanked on the right stitch length or tension settings especially when switching between different fabrics. The idea of using cheat sheet labels is so simple but so genius. I don’t know why I never thought of it before! I’ve always relied on scribbled notes in random notebooks or worse just winging it. This is going to save me a ton of frustration, not to mention thread. I run a small domestic corporation that makes handmade leather accessories, and consistency is everything when we’re fulfilling bulk orders. One off stitch and it ruins the clean aesthetic our customers love. Having these quick reference labels directly on the machine would help streamline our production process a lot. Definitely planning to implement this for each machine in our workshop. Honestly, it’s the little things like this that make a big difference in a busy workspace. Big thanks to the original poster and everyone who chimed in. Super helpful tips this community never disappoints! Bookmarking this one for sure. Quote
