Members Michael Schwartz Posted August 27, 2016 Members Report Posted August 27, 2016 All Walking foot machine users. Like the rest of you, I was somewhat dismayed over the walking foot marks left in my projects by the machine, especially in softer leather. I purchased a replacement foot and, using a grinder, I ground off the teeth on the bottom of the foot. Then I took the foot to a diamond plater, who fortunately is a good friend of mine. We chose the appropriate diamond size and type and plated a layer of diamond on the bottom of the foot. The coefficient of friction seemed right so I installed the foot on my machine. As you can see from the photo, the marks from the original "toothed" foot are on the right and the left two rows are from the diamond plated foot with absolutely no changes in pressure settings, only an interchange of the feet. As you can see, the marks are significantly reduced and I feel like I can use the patcher again for my projects where the foot marks are not tolerable. Contact me if you are interested in purchasing a diamond foot for your machine. If a replacement foot is available, I can get one and plate it for you for $25 plus the cost of the foot. Quote
bikermutt07 Posted August 28, 2016 Report Posted August 28, 2016 Great thinking. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members PeteBuh Posted August 30, 2016 Members Report Posted August 30, 2016 Looks pretty good. What is diamond plating? Do you actually affix ground up diamonds to the bottom of the presser foot? Quote
Members brmax Posted August 30, 2016 Members Report Posted August 30, 2016 That's a neat idea, so about .025" thick, how is that connected epoxy. I always did like the feet to be the same length so as not to need adjusting if getting real serious changing from several others like blanket, cording, etc.. Quote
alexitbe Posted August 31, 2016 Report Posted August 31, 2016 After removing the teeth, why not simply sandblast the base to make rough and then polish by hand to the smoothnes you wish? Quote
Members ndnchf Posted August 31, 2016 Members Report Posted August 31, 2016 I read somewhere about gluing a piece of 400 grit sandpaper to the bottom foot after grinding down the teeth. Not as classy a solution, but it works. Quote
Members dikman Posted August 31, 2016 Members Report Posted August 31, 2016 If you grind off the feet then depending on the grit you use you can get either a smooth polished foot or a rougher finish to give a bit of grip. I find a belt grinder very useful for re-shaping feet. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
alexitbe Posted September 1, 2016 Report Posted September 1, 2016 7 hours ago, dikman said: If you grind off the feet then depending on the grit you use you can get either a smooth polished foot or a rougher finish to give a bit of grip. I find a belt grinder very useful for re-shaping feet. This sounds the most sensible and easiest thing to do. The grinder/sander is something that almost everyone will have access to Cheers Alex Quote
Members Michael Schwartz Posted December 23, 2016 Author Members Report Posted December 23, 2016 The Diamond is bonded to the foot with a proprietary overplating method (It's nice to have a friend in the diamond plating business) The huge advantage of the the Diamond plating over simply sandblasting, roughing up the surface or gluing sandpaper to the foot is that the Diamond is permanently bonded to the foot and will basically last longer than the machine itself. In addition, it is easy to choose different Diamond size and grit density for different materials. Simply grinding the foot may work for a while but the leather will quickly wear down the roughness created and the feed will become inconsistent. There is also a significant danger of grinding unevenly causing the foot to feed on a bias or possibly ruining the foot altogether. I am currently selling 21K feet as fast as I can make them. They sell for $65 each with free shipping in the continental US. Multiple feet discounts are available. Contact me if interested. Quote
Members sarahagel Posted October 17, 2020 Members Report Posted October 17, 2020 Any chance you're still selling these presser feet? Thanks, Sara Quote
