Just thought I'd mention that I have what people have been asking for.A DC motor with
a built-in reducer,which mounts like all the other motors but eliminates the lining up & drilling holes required when mounting a reducer & motor separately and for less $$ too.
Believe the man, he has the cure...these motors work great and I can sew so slow now on my Adler 105-64 that I am able to fall a sleep and and still dont have more then one stitch at the time when I wake up...LOL...!! And you are talking added penetration power!
Well spend money in my book!!
tnx Bob!!
http://www.elfwood.com/~alien883
First it is just leather....then it is what-ever I can dream off...
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
  • 7 years later...
Cowboy Bob,
I know this is an older thread, but I have the same machine as gavingear and am about to replace the original motor. Nothing wrong with the motor, I just want one that I can run slower, when desired. I run it fast sewing long seams, but would love to be able to do more intricate work and therefore need a more appropriate motor, a more modern one. When the servo motors first came out, I bought one for another machine I had at the time. But it died on me after only months of using it. I know the servo motors have evolved since then and they seem more affordable, depending on what you get of course. What would you suggest for my Pfaff 545 High lift? Thanks ahead!
Yes,we had problem with the digital readout ones blowing a chip in them.We don't sell them unless someone wants one.We sell a more simple one that has a knob on the front to set the top speed.They run as slow as 300rpm & since they have brushes in them retain a lot of torque @ low speed.
http://www.tolindsewmach.com/motors.html
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Thanks for that information Bob! Much appreciated. I will be contacting you. :)
  • 2 months later...
Bob, I'm ready for that motor now! I will be giving you a call!
Ok,I just got back from Weavers & bought 32 machines!But I'll be in tomorrow.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Wow Bob, from Weaver leather? what kind of machines did you buy. I hope you got better prices than on their web site. Nearly 5K $ for a Adler 205-370 clone (with 16 "arm). "But as close to an original Adler as we come" still is not a Duerkopp Adler machine. You know the story behind these, Thanks, Tor
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
  • 1 year later...
To begin - a big thank you to all the knowledgeable people who share their expertise and excellent sense of humor on this website! Can't imagine attempting anything related to these big machines without you!
So...I'm hoping someone knows the answer to my question. I recently acquired a Pfaff 545 H3 - 6/01 CLMN (whatever that all means). I bought it with the intent to sell. It came with the entire table set up as well as three huge bobbins. It was covered in dust but no rust and the underside looked good (meaning clean, no rust and no oil build-up). It sews - very well, I might add. It's freaking amazing is what is it. Huge, powerful, and I'm finding it relatively easy to work on in terms of cleaning and understanding the functions of all the parts.
I took off the tension assembly in the front - all the pieces came off. I took photos so that I could remember where everything went. When I removed the metal plate that held the two tensioners in place (part #91-000 412-25 on the diagram), there was another piece of black metal screwed to the back of it (#91-010 186-15) . Then when I unscrewed that piece to take it off to clean it, I heard that dreaded sound of metal hitting the floor. A teensy tiny metal rod (#91-010 185-05  ) had fallen out and I haven't a clue as to where it goes or what it does on the machine. It's circled in red on the parts diagram, but there is no indication of where it goes or how it attaches.
Is there someone out there who can help? Thanks in advance!
Edited by MaryLee
That is the tension release rod. Feed it inside the hollow threaded post that holds the tension disks and release plate, spring and thumbscrew. If that little stud is perfectly straight, it can go in from the back before you reinstall the tension release bracket. If it has a bigger end on one side, or if the release bracket is already screwed down, feed it in from the front through the hollowed post. Then install the two disks, the metal plate that the little sud pushes against, the beehive spring and the nut.
Some things are better left alone, if you know what I mean.
Posted IMHO, by Wiz
