Members Big Sioux Saddlery Posted September 2, 2016 Members Report Posted September 2, 2016 8 hours ago, CaptQuirk said: @Big Sioux Saddlery- I usually work with 6-10oz leather, no reason for me to go that heavy. And I really can't afford one of each. I wanted a Blonde and a Redhead, but couldn't afford both of those either... Anyways, I am a beginner. That said, if I had to choose between one or the other, which strap cutter am I likely to mess up the most leather with? The wooden one will work just fine for what you want to do, and IMO will be easier to learn to use. Everyone screws up a strap with a draw gauge at some point. Occasionally I still do. I have "The Original Strap Cutter" so I would recommend that over the Tandy model, just going off of the quality of most of the rest of Tandy's stuff. Keep a sharp blade in it and they're pretty easy to use. Curves. . . it depends on how much of a curve you're talking about. Sometimes, a curve will develop along the straight edge that you're cutting from, just due to the difference in the density of the leather throughout the length of the hide. A subtle curve is no problem to follow. A sharp or abrupt curve could be a little more difficult. Quote
Members CaptQuirk Posted September 2, 2016 Author Members Report Posted September 2, 2016 Don't need a huge or sharp curve. I posted about the western gunbelt I made not fitting right, and was told to cut it on a curve. It looked like maybe 1-2 inches from the example shown, over the length of the belt. Quote
Trox Posted September 2, 2016 Report Posted September 2, 2016 That was a nice modification Red Cent. It's also smart to take of some of the edges on the wooden bar (see pic), This way it will not leave marks on the remaining leather and are easier to feed in too. (it's a Stohlmans trick). I got a brand new one (top) I can sell if is hard to get the original, I'll keep one because they are good on very thin leather. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Contributing Member JLSleather Posted September 2, 2016 Contributing Member Report Posted September 2, 2016 I got a wooden one. Don't know how "original it is", but I just cut strips... the art don't start til after that part... Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members CaptQuirk Posted September 2, 2016 Author Members Report Posted September 2, 2016 I am currently mastering the art of screwing up leather, as my blade tends to wander. Anything has to help. Trox, nice tip, thanks. Quote
Members Red Cent Posted September 3, 2016 Members Report Posted September 3, 2016 The dowel rods do hold the leather for you. It makes cutting thin leather very easy and straight(er). I sometimes use 3-4 ounce veg tanned as a liner and it cuts it very well. 8-9 ounce is real easy. They also free up a finger or two. Stumbled onto a another trick that be done to the wooden strap cutter. I started using the blades for the safety beveler and fixing the tool so that the blades are placed at an angle. Either bottom back or top back. I ran out of the strap cutter blades and accidentally put the beveler blade in the slot and did not know it was at an angle. Amazed how easily it cut 8-9 ounce leather. Trox, since that picture, I rounded the edges. I saw the parallel shiny mark too. Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Members Ken Nelson Posted September 3, 2016 Members Report Posted September 3, 2016 I use an original wood strap cutter and have used it for over 20 years. I cut everything in straps from saddle strings to stirrup leathers from 15 oz HO. I got started using it because I was getting some children visiting my shop and thought it might a bit less dangerous if one of them picked it up to "look" at it. I keep a supply of strap cutter blades on hand and will break one once in a while and change them regularly. I block my stirrup leathers out, and dunk them quickly before I cut them. There is a guy in Libby, MT that builds a super good blade for a draw guage. Brett Bronson custom knives, and they come super sharp. 406-293-2032. Quote
Members CaptQuirk Posted September 3, 2016 Author Members Report Posted September 3, 2016 Thanks for all the tips and suggestions. I pulled the trigger on an Original from the BuckleGuy. $29.00 seemed about a mid level price, between the knock offs and a cheap draw gauge. Before dropping this thread, I'll ask again about cutting curved belts. I want another crack at cutting a gunfighter belt, about 4", which is the max for one of these strap cutters? Can it cut that on a curve, and how much trickier is it than cutting a regular strap? Quote
Northmount Posted September 3, 2016 Report Posted September 3, 2016 15 minutes ago, CaptQuirk said: Before dropping this thread, I'll ask again about cutting curved belts. I want another crack at cutting a gunfighter belt, about 4", which is the max for one of these strap cutters? Can it cut that on a curve, and how much trickier is it than cutting a regular strap? If the edge you are cutting from is on a curve, the guide will follow the curve, and of course the knife is parallel to the guide, so it does cut curves. The radius will be limited at some point. The smaller the radius, the harder it will be to guide the cutter. Tom Quote
Members CaptQuirk Posted September 3, 2016 Author Members Report Posted September 3, 2016 Ok, thanks northmount. Quote
