On ‎1‎/‎10‎/‎2017 at 3:55 PM, Dwight said:
Shielajeanne, . . . find a friend who is an electrical contractor, . . . tell him / her you need several short pieces of 1/2 and 3/4 inch EMT, ElectoMetallicTubing, . . . or conduit as it is commonly known.
Cut them about 6 or 7 inches long.
Here comes the fun, . . . very gently, . . . very slowly, . . . take your time, . . . be very deliberate, . . . and keep a pan of water close by to dip it in every 4 or 5 seconds.
Take a couple of those pieces to a disc or belt sander with something between 120 and 200 grit sand paper on it.  Bevel the edge all away around at about a 60 degree angle, . . . be careful not to burn the steel, . . . go slow and keep dipping it.  GET IT SHARP, by grinding until you have a really good edge on it.
Next take a hack saw and come up about 1 inch, . . . cut the tube about half way through, . . . make the final cut starting on your sharpened edge, . . . going down to where you made your cross cut.  You wind up with a tool that will cut a beautiful half circle with some light tapping of a mallet.  Dampen your leather first, . . . they go through like hot butter.
For your window you want to cut (inside corners) you cut away half of the half circle, . . . leaving only a 1/4 circle, . . . and again they work wonderfully.
The below pictures show some of the ones I have made, . . . and use on pretty much a daily basis.
The top left hand corner is a 3/4 inch tool for cutting really nice rounded ends on 3/4 inch straps.  Clockwise from it is a 1/2 inch hole puncher and all the way on the right hand side is the 3/4 inch hole puncher.
The bottom left tool makes beautiful half round cuts, 3/4 inch size, . . . the lower right tool makes your corner cuts, . . . it's also 3/4 inch in size.
May God bless,
Dwight
That is the way to go, never have to buy a hole punch again
I have to buy some, . . . but these are better made than bought, . . . I can then "make" them to suit my purpose better.
May God bless,
Dwight
www.dwightsgunleather.com
