Members Bluefever Posted May 20, 2020 Members Report Posted May 20, 2020 On 2/6/2017 at 6:17 PM, mixmkr said: My plate had the numbers 98-11 and the slots didn't quite line up with the holes in the bed.... so a little dremel-ing fixed that as you can see. Earlier in the thread I had a picture before, where I just used one screw with the tabs not really doing anything, hanging off the side. After a bit, it tended to shift, but won't now. And yeah...why drill the machine bed when you can drill a lesser expensive bracket instead? Any idea on where I can purchase this 98-11 mounting bracket? I have searched by 98-11 and cannot find anywhere. Quote
Members nylonRigging Posted May 21, 2020 Members Report Posted May 21, 2020 (edited) 3 hours ago, Bluefever said: Thank you for the reply. My machine does Not have holes in the slide plate to the right of the needle. Unfortunately. So you do have a R-side slide plate . But you saying .." no holes drilled in it " ? All you have to do is just drill and tap your own holes in the slide plate to mount a fixed position or a swing-arm bracket for your seam binder . Then just drill/tap a keeper screw for plate hold down to stop any slide moment while sewing . It pretty straight forward to do and slide plates are cheap . It more compact than that added extra hardware, and all you do is remove the slide plate with binder , and slide in another plain flat plate if want to use machine other than binding . --- I have owned that exact larger bed bracket swing-arm years back on a seam binder attachment, along with the single smaller swing-arm bracket that is screwed to the Side slide plate in the Pic . and also still have and use a few binders with only using the slide plate mount swing brackets. In the Pic. by (mixmikr) . There is actually ( 2 ) swing-arm hinge brackets, there doing one job . a smaller swing-arm bracket screwed to the slide plate, and also a swing-away hing back on the Bed mount bracket attached to it . To each there own, but ( to me ) it a little redundant for 2 swing-arm brackets with using one binder attachment . I never liked that large hardware bracket and it did nothing but eat up a lot of room, and did not accomplish anything the small slide-plate mount swing-arm did with seam binding a job . The single smaller hardware, swing bracket on R-side slide plate, with seam bind attachment will do your work perfectly by itself . So Why ? then you join to a larger hardware, with swing bed mount bracket ? . . ( less is more ) and 1 mounted on the slide plate is better than ( 2 ) swing arms . . 2 swing arms is also double the hardware and it also leads to more adjustment moving movements, and added problems with hardware moving and falling out of your set adjustment . . Edited May 21, 2020 by nylonRigging Quote
Members keithski122 Posted May 21, 2020 Members Report Posted May 21, 2020 This is how I mounted a binder to my machine, I need to change the binder size but should work well like this.Also nice and easy to fit or remove. Quote
Members nylonRigging Posted May 22, 2020 Members Report Posted May 22, 2020 7 hours ago, keithski122 said: This is how I mounted a binder to my machine, I need to change the binder size but should work well like this.Also nice and easy to fit or remove. - Hows that Binder set-up tracking on the fold and feed to your materials ? With that Binder throat screwed down flat like that to slide-plate . Just wondering because I have set-up a lot of Binders on slide-plates, and looks like you have very little ways of changing throat angle positions ? talking about Deg. of angle changes, for throwing Binding feed, flowing top or Bottom side on the sew . --- I REALLY prefer a small swing bracket with 90 deg. throat, off the slide-plates for a 1st choice . But, If I had my mind made up for a larger hardware, bed-mount swing-bracket . The one that ( Gregg from Keystone ) put up in that pic. in his Post above in the Thread . I have had that larger swing-arm Bed mount, that Tenn.Attachment Co. set's-up . If going that direction... That would be my only go-to choice . as it a hardcore piece of craftsmanship they put out . . Quote
Members keithski122 Posted May 22, 2020 Members Report Posted May 22, 2020 To be honest I have no idea how its set up, I just bolted it on so the material to be bound was in roughly the right position with the needle in roughly the right postion and it seemed to work. Its to be used for binding carpet with vinyl material but the thickness of the vinyl causes it to stretch slightly so I need to get a binder with a thicker gap for binding material. Quote
Members SARK9 Posted May 22, 2020 Members Report Posted May 22, 2020 (edited) I've been using a bobbin cover to mount and switch the various binders I use for quite some time....These top-load machines make it very convenient to lock the binders in the position needed to perfectly run the different material/binder combinations, and retain those settings without wasting any time or material to resume work every time you change binders. Simply switch out to another pre-adjusted cover plate/binder combo, or back to a plain cover plate as needed. I shop-make my own plates from mild steel in batches. Machine shown is an old 111W152 someone discarded, resurrected as a dedicated binder. If you don't install a binder needle plate and foot set on these walking foot machines, you may chase your tail for an epoch or so trying to get decent results. DISCLAIMER: I only use this setup on heavy fabrics needing various inside curves, and I mostly use the double fold styles with my own bias tapes. I can't find the odd colors needed in any purchased tapes or webbing. -DC Edited May 22, 2020 by SARK9 Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Members nylonRigging Posted May 22, 2020 Members Report Posted May 22, 2020 24 minutes ago, SARK9 said: I've been using a bobbin cover to mount and switch the various binders I use for quite some time....These top-load machines make it very convenient to lock the binders in the position needed to perfectly run the different material/binder combinations, and retain those settings without wasting any time or material to resume work every time you change binders. Simply switch out to another pre-adjusted cover plate/binder combo, or back to a plain cover plate as needed. I shop-make my own plates from mild steel in batches. Machine shown is an old 111W152 someone discarded, resurrected as a dedicated binder. If you don't install a binder needle plate and foot set on these walking foot machines, you may chase your tail for an epoch or so trying to get decent results. DISCLAIMER: I only use this setup on heavy fabrics needing various inside curves, and I mostly use the double fold styles with my own bias tapes. I can't find the odd colors needed in any purchased tapes or webbing. -DC That bottom Pic. . ( looks like ? ) You running a raised feed dog and raised throat plate, in conjunction with your Binders hardware . Once I started doing that it became much more easy getting the results I wanted . Your comment on ..." I can't find the odd colors needed in any purchased tapes or webbing ". .. finding that right color for your binding tapes I can relate to ..LOL . It can be a big PIA . That is a job in searching and sometime I just give up and just have a color dye run done at Bally Ribbon . If they don't have it in-stock, they will do you a color dye run for your binding or your webbing . there quality is always A+, and your get what you need. . Quote
Members SARK9 Posted May 22, 2020 Members Report Posted May 22, 2020 1 hour ago, nylonRigging said: 1 hour ago, nylonRigging said: That bottom Pic. . ( looks like ? ) You running a raised feed dog and raised throat plate, in conjunction with your Binders hardware . Yes and Yes. I think this is the budget set that has all the parts in one go: https://www.ebay.com/itm/162817911154 Quality wasn't too bad, but it did require a tiny bit of fitting. -DC Quote Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562, Mitsubishi LS2-180, Seiko SK-6, Juki LG-158-1
Members nylonRigging Posted May 23, 2020 Members Report Posted May 23, 2020 (edited) 1 hour ago, SARK9 said: Yes and Yes. I think this is the budget set that has all the parts in one go: https://www.ebay.com/itm/162817911154 Quality wasn't too bad, but it did require a tiny bit of fitting. -DC ya that Co. ( cutex sewing ) , i have bought a lot of odds and ends from them over last few years. Some are pretty good some not. I would guess about 1 or 2 out of 10 things are subpar on the quality, but the prices are China-Low so you can afford to just throw them away if they fall to far out of Spec. . That is a good price on the 'raised' single-needle plate and dogs . makes setting up single-needle Binding a much easier road on the old singers . I run a couple double-needle machines on binding and am pretty limited to where to get for, 'raised' dogs and plates for 2-needle Gauge sets . About only place I know of to get them is direct from Tenn. Attachment . Would love to find ? .. a less expensive alternative on the raised double-needles sets, so I could set-up several more gauge sizes on the needle spreads . . Edited May 23, 2020 by nylonRigging Quote
Members usmc323 Posted January 7, 2022 Members Report Posted January 7, 2022 Where can I get the bracket to attach to the machine. This is the square two hindged that wraps under the bed? Quote
