Uwe Posted February 10, 2017 Report Posted February 10, 2017 (edited) I'm certainly not the first one to do this and tables that are designed with wheels in mind are the best solution. But I wanted to figure out a way to retrofit my tables with removable wheels that wouldn't raise the table much and be very sturdy. I spent the day at Techshop to put my Adler 467 on "proper" wheels. I have to move it from storage area to the work area whenever I want to use it. It's been strapped on top of mover's dollies, but that was just a temporary solution and not very ergonomic at all for actual sewing. Here's what I came up with today. Perhaps it'll inspire some folks to make something similar or to improve upon my design. Design goals: Wheels must install without tools and be easily removable. Raise table less than 2" (5cm) to keep table height and pedal ergonomics good. No modification of original table legs. Lockable swivel castors. No decrease in overall stability. This project has been bouncing around in my head for some time. The solution shown here consists of two skateboard-like units that clamp onto the original legs on either side of the table. The hinged wheel units on each end clamp onto the floor mount tabs of original table legs. The weight of the table provides the clamping force via hinge levers - the heavier the table, the stronger the clamping force and thus stability. Total cost of materials was about $50 ($25 for the four swivels castors, $15 for 2'x4' fancy phenolic 3/4" plywood, $10 for fours hinges.) Here's what the table looks like wth the new wheels: These close-ups show how the hinged wheel end units clamp down on the tables mounting plates: Here are the parts for one of the wheel units (seven 3/4" plywood pieces, two locking swivel casters, two hinges): The center support board is connected to the two wheel end pieces via hinges - this provides the clamping action to hold the unit in place. The two end pieces have a vertical offset like a fifth-wheel trailer to keep the center support board low enough for good ergonomics of the table and pedal. The sides walls of each wheel assembly are spaced to fit snugly around the table's vertical metal legs to provide support against sideways tilting. It takes more than one person to put these wheel "boots" on. Taking them off is easy - just lift up one end of the table and the wheel boots fall off. The footprint of the wheeled table is considerably deeper front to back, compared to the original table. This provides room for the swivel casters to rotate 360˚ without compromising front-to-back stability. This setup is not going to tip over backwards when you tilt the sewing machine head back. Edited February 10, 2017 by Uwe Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members mixmkr Posted February 10, 2017 Members Report Posted February 10, 2017 I'm thinking either a DC battery and an inverter to run the sewing machine motor, which now has an extra long shaft to provide a 2nd pulley. Of course you know where the belt on the 2nd pulley now goes to. :-D >>>hhhmmm steering.... have to think that one out. Clever idea with the hinges. Regular Nascar type car jack might make install a one man-er. Quote JUKI LU562, Singer 107 W1, Thompson PW201 mini walker, a couple of plastic fantastics for light duty "home stuff".... ya know...fixin' and altering clothes.....
Evo160K Posted February 10, 2017 Report Posted February 10, 2017 That's impressive!! Looks outstanding to me. As a side bar Uwe, the 45K shuttle came in today.....fast and beautifully packed......very professional. Thank you Quote
Members Constabulary Posted February 10, 2017 Members Report Posted February 10, 2017 (edited) Once again well done Clever idea! Next thing I want to see from you is a hoover board for sewing machines tables. I mean Nike now has the self tying shoes so.... Edited February 10, 2017 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members suzelle Posted February 10, 2017 Members Report Posted February 10, 2017 Uwe's a smart one! I have thought of this often (how to put wheels) on my commercial sewing tables. All (3) of my big embroidery machines have nice wheels on them, so easy to clean around them or move them. I have to come up with a solution for my commercial sewing machine tables though, so thank you Uwe! Quote
Members gottaknow Posted February 10, 2017 Members Report Posted February 10, 2017 Nice Uwe! We use Kessler tables which are height adjustable with a crank handle since operators come in all sizes. We also have some set for stand up operation. They are on wheels as well since we rearrange the factory quite often. Your design does resemble the Kessler a bit. Well done. Regards, Eric Quote
Members Yetibelle Posted February 10, 2017 Members Report Posted February 10, 2017 That is a great build. I like how you kept it low so you can sit and sew at it while its on the wheels. nice work! Quote One day I hope to learn how to sew..... Singer 111W155 - Singer 29-4 - Singer 78-1 - Singer 7-31 - Singer 109w100 - Singer 46W-SV-16 - Adler 20-19 - Cowboy CB-4500
Members chuckgaudette Posted February 10, 2017 Members Report Posted February 10, 2017 I've been wanting something like this for a long time Quote
Members sandyt Posted February 10, 2017 Members Report Posted February 10, 2017 Sometimes I am surprised what one can do with wood. Nice, I could use one. Quote
Members MsMustard Posted February 7, 2021 Members Report Posted February 7, 2021 Hi have read a million of your posts to help me with my Pfaff 145. I don't sew leather, but there is a wealth of information on this website that I really appreciate. Hope you don't mind me digging up an old thread. Just wanted to say this is a really nice idea! Thank you! Quote
