depends how big the slot.  Usually, a modeling spoon works.
5 leather patterns
One of the few areas where I'll say I don't bother.  With the belt running in and out, it's going to burnish itself or get roughed up.  One of the other in quick order.  I've never had a comment about it either.  If I wanted to I have a burnisher in my drill press with a point that will get in there and burnish it.  I just don't see the point.
The fastest and easiest way I have come up with is done with a 60 or 80 watt soldering iron temperature controlled through a light dimmer switch.We do all holes in our belts this way including the crew punch slot for the buckle. Takes a bit of practice but gives excellent results and on belts that sell between $200 and $500 that is what you gotta do I reckon.See pics. The tip get shaped to suit and polished generally every 200 or so belts.
YouTube Channel
Instagram
Average time on the 5 holes on both sides is about 40 seconds with practice. It is not so much burning as it is ironing which at the end of the day is mostly what burnishing is without so much rubbing.If you want to try without the dimmer switch try rubbing a bit of furry edge leather high up the shaft nearer to the handle. A quick wipe should smooth in the nap quite well.
YouTube Channel
Instagram
