Members dikman Posted March 27, 2017 Members Report Posted March 27, 2017 I have a Pfaff 335 which is mounted on a conventional table, which makes it look like there's a lot of wasted space. I've been looking at some of the minimalist-type tables that the Cowboy-type cylinder arms etc use and wondered what are the pros and cons of using this type of table? It would certainly have a smaller footprint and would be practical to fit wheels to and make it somewhat moveable. Could be an interesting project. Do you folks who use these tables find they have any serious disadvantages? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members brmax Posted March 27, 2017 Members Report Posted March 27, 2017 Im not sure on which descript in a mobile table im only recalling the typical 4500 stands. On some other ones with top that has a center open design i can see them being easily mobile. Myself struggle with to many seats and heights so try to keep my ocd pattern the same with machine setup. Floyd Quote
Members dikman Posted March 27, 2017 Author Members Report Posted March 27, 2017 Sorry mate, should have posted a picture. The only one I could find in a hurry is on this page - http://www.tolindsewmach.com/cowboy.html Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members kellyblues Posted March 27, 2017 Members Report Posted March 27, 2017 I have a Consew 227R on a conventional table and find it quite handy having the extra work space. Quote Home of wayward and unwanted sewing machines, big and small. Too many to list.
MADMAX22 Posted March 27, 2017 Report Posted March 27, 2017 I am planning on building a similar small table as my 441 for my 153w so I can get it in operation. Ill make it a little more stable then the 441 table though. There are two types of 441 tables I have scene, the one with the square post that bolts directly to the base and the one that has the welded angle base attachment. The direct bolt on one is a little rocky IMHO and if you got a wheel stuck or weren't careful Im pretty sure it could tip over when moving it. Quote
Members patria Posted March 27, 2017 Members Report Posted March 27, 2017 I am too in the need of more space, so i am currently trying to build a custom iron stand similar to dikman's picture of a cowboy setup on my friend's metal workshop. I'd like to buy one initially, but no sewing machine store here has them on stock, some of them even barely know about table set up like that Leather sewing machine business in Indonesia a bit slow i think, most of leather shops here are using "minimalist" set up and get "creative" trying to squeeze out more from their simple tools / machinery. Quote
Members dikman Posted March 27, 2017 Author Members Report Posted March 27, 2017 Madmax, I too thought that the single central support could be a little wobbly, unless it was made particularly thick! I have a spare set of legs from a table and was toying with the idea of using them to make a narrow version of a "standard" table. It wouldn't be quite as compact as the Cowboy table but should be more stable. Failing that, making one with four vertical posts, one in each corner, might be another option, although making something like that with adjustable height might be a bit of a problem. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members kellyblues Posted March 27, 2017 Members Report Posted March 27, 2017 I have had the same concern about the support on some of those. Particularity the Cowboy CB-4500 because I'm going to make the trip over there very soon to purchase one. I've heard they are surprisingly sturdy despite the appearance. Quote Home of wayward and unwanted sewing machines, big and small. Too many to list.
Members dikman Posted March 27, 2017 Author Members Report Posted March 27, 2017 This is what I currently have, and seems like a lot of wasted space (at least for what I do). I guess the simplest option would be to cut the table back to the actual leg width. This will reduce the width by 14" to 32". Next option is cut and weld the two horizontal metal bars to reduce the width even further. Either way is going to be a lot less work than building a new table. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
MADMAX22 Posted March 27, 2017 Report Posted March 27, 2017 1 hour ago, dikman said: I guess the simplest option would be to cut the table back to the actual leg width. This will reduce the width by 14" to 32". Next option is cut and weld the two horizontal metal bars to reduce the width even further. Either way is going to be a lot less work than building a new table. I did that for my 111w table since I am not making sails and stuff, it works pretty darn good. One thing I will do in the future is the same thing but put a removable extension piece so when I dont want an extra 2 feet I put it away on a shelf. Quote
