Hi friends,
l am would love to first paint /stain my vegetable Tanned Learher and there after take it in for laser engraving. I don't want the etching process to affect the color of my leather. Can anyone recommend a seal that will protect the leather or even take me through the process if they have done it before. I appreciate all your help and advise friends. Waiting to hear  and learn from y'all. Thank you.
Edited by Katlyn4jc
The laser must affect the leather, it burns it.  If you mean the other parts of the leather that the laser is not aimed at, it is not a problem.  The ash from the laser burned area can smudge, like any other burned charcoal will.
If it is a legit laser it *should* have a compressor blowing air directly at the laser as it cuts. This helps remove any debris that gets sucked up into the dust collection system and also keeps the product from overheating/catching fire. Without owning one I think you should be fine with keeping the rest of the product unharmed.
Rob
www.ridgewayleatherworks.com
IG: @Ridgewayleatherworks
FB: RidgewayLeatherworks
17 hours ago, Katlyn4jc said:
Thanks friends. What sealant works base for leather that is to be laser etched?
I've made stuff that is laser engraved.  Electron and Jersey are both right.  The laser burns the leather. The laser should have what is called an Air Assist that directs a stream of air at the surface where the beam is hitting.  The laser also has a good fume/smoke exhaust system that is sucking the stuff out the rear of the engraver.
As long as the user is not using too  much power and generating excessive smoke and soot, all is well.
I use Leather Balm with Atom wax as a sealer.
I think the real problem will be getting the piece lined up so the laser pattern will exactly follow the painted/stained pattern.  Maybe mark up the platen the leather is to be placed on, do a light burn, then paint/stain and then re-position exactly where it was to do the final burn.  Anyway, you will need to work closely with the laser owner/operator.  You will need to have the pattern in an adequate format for the laser.
Tom
Tom
If you are trying to engrave a design that you can paint, you'd want to cover the leather with blue painters tape and engrave through that.  Then, lightly wipe it to get any soot off and paint over the tape. You are essentially using it as a mask.  Let it dry thoroughly and peel off.
  • 2 weeks later...
