Members cjartist Posted August 4, 2017 Members Report Posted August 4, 2017 I was looking for a motorized burnisher to save my hands. Hand burnishing is okay for small things but when you move into working with long edges ... Uggh! So I was looking around for options and I ended up with this setup. I had the cheap Harbor Freight bench grinder that I got on barter a couple years ago. The spindle was $13.10 from eBay http://www.ebay.com/itm/TAPERED-SPINDLE-1-2-HOLE-RIGHT-SIDE-OF-MOTOR-POLISHING-BUFFING-WHEEL-HOLDER/190689483141 And the wheel was $8.00 from Tandy. Yeah, I'm cheap ... broke is more like it. But I highly recommend this setup for anyone that needs a little help doing edges and doesn't have a fortune to spend. Enjoy! Quote Check out my Unique Marketing Strategy and see if it might also work for you to get paid for your art.
garypl Posted August 4, 2017 Report Posted August 4, 2017 Did you just jam the burnisher onto the spindle? Quote Cowboy 4500, Consew 206RB-4
Members Fire88 Posted August 4, 2017 Members Report Posted August 4, 2017 Ive been thinking of doing something very similar, Good work Quote
Members AdamGadut Posted August 4, 2017 Members Report Posted August 4, 2017 you may want a burnishing wheel with more varieties in the thickness it can burnish - maybe 5 in one burnisher. Two is ok if that covers everything you do though. Quote ----------------------------------------------------------------------
Members cjartist Posted August 5, 2017 Author Members Report Posted August 5, 2017 (edited) On 8/4/2017 at 8:26 PM, garypl said: Did you just jam the burnisher onto the spindle? Expand No, the spindle is threaded in the opposite direction of rotation. The wheel is just hand turned on and the spindle essentially threads itself into the wood. It becomes self tightening when it meets resistance. This is typically used with polishing wheels by jewelers. Edited August 5, 2017 by cjartist Quote Check out my Unique Marketing Strategy and see if it might also work for you to get paid for your art.
Members dikman Posted August 13, 2017 Members Report Posted August 13, 2017 That's actually quite a clever way to mount the burnisher! It never occurred to me when I was making my burnishers - so simple that I missed it. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members cjartist Posted August 15, 2017 Author Members Report Posted August 15, 2017 On 8/13/2017 at 5:29 AM, dikman said: That's actually quite a clever way to mount the burnisher! It never occurred to me when I was making my burnishers - so simple that I missed it. Expand Thanks, I only found the solution out of necessity of not having the $$. It works quite well too. All that I need for now Quote Check out my Unique Marketing Strategy and see if it might also work for you to get paid for your art.
alpha2 Posted August 15, 2017 Report Posted August 15, 2017 Note that there are right hand spindles and left hand spindles. If you use the wrong one, instead of tightening under load, it runs off and shoots across the floor!!! Quote So much leather...so little time.
Members cjartist Posted August 16, 2017 Author Members Report Posted August 16, 2017 On 8/15/2017 at 11:39 PM, alpha2 said: Note that there are right hand spindles and left hand spindles. If you use the wrong one, instead of tightening under load, it runs off and shoots across the floor!!! Expand Ha ha, yes very important to be sure to buy the right one. That truly could be an expensive mistake ... "be careful kid, you could take an eye out with that thing" Quote Check out my Unique Marketing Strategy and see if it might also work for you to get paid for your art.
Members dikman Posted August 17, 2017 Members Report Posted August 17, 2017 Actually, unless you've got something completely different on your side of the pond, every grinder that I've come across has had a left-hand thread on one side and a right-hand thread on the other. It is impossible to fit the wrong spindle on the wrong side, so whichever side you use it will always tighten up (unless you some how manage to reverse the motor direction). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
