Members Ernie92 Posted September 7, 2017 Members Report Posted September 7, 2017 Hey everyone, does anyone have experience with actually setting up A rotary phase converter for a an Atom 25 SE clicker? I just set up my phase converter that I bought from American rotary phase converter. I'm 100% sure I've set up the phase converter properly and correctly. But after I apply the load from my Adam clicker the clicker itself doesn't seem to actually come on or starred up. Is there's something I'm missing here? I can't seem to figure it out. Any info would help thank you. Quote
Members Pt 109 Posted September 7, 2017 Members Report Posted September 7, 2017 If you have the phase converter wired to the clicker backwards the flywheel will turn the wrong direction thus causing the clicker to not work. Check the rotation of the flywheel. It should have a arrow on the flywheel to show correct direction. Quote
Northmount Posted September 7, 2017 Report Posted September 7, 2017 If wrong rotation, and this is a 3 phase motor, reversing any 2 leads will change the direction of rotation. Tom Quote
CowboyBob Posted September 7, 2017 Report Posted September 7, 2017 Have you checked w/a voltmeter that your getting voltage on 2 of the wires? Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Sonydaze Posted September 7, 2017 Members Report Posted September 7, 2017 9 hours ago, Ernie92 said: Hey everyone, does anyone have experience with actually setting up A rotary phase converter for a an Atom 25 SE clicker? I just set up my phase converter that I bought from American rotary phase converter. I'm 100% sure I've set up the phase converter properly and correctly. But after I apply the load from my Adam clicker the clicker itself doesn't seem to actually come on or starred up. Is there's something I'm missing here? I can't seem to figure it out. Any info would help thank you. I'm not sure if you are saying that the clicker will not cycle or that the motor on the clicker is not turning. If the clicker won't cycle then the motor is likely running backwards as suggested above. Reversing two leads will change this. If the clicker motor is not turning properly (it will turn slower and make an unhappy noise on single phase), then you have a problem with the phase converter. Quote http://www.bound2please.com Sewing machines: 3 - Sunstar 590BL, Artisan Toro 3200, Juki LK-1900HS, Juki DDL-8500-7, Juki DDL-5550N, Pfaff 138-6/21, Pfaff 546-H3, Pfaff 335-H3, Adler 221-76, Singer 144WVS33, Singer 29K-51, Siruba 747B
Members Ernie92 Posted October 17, 2017 Author Members Report Posted October 17, 2017 Hey everyone finally fixed the problem. It's was actually a bad fuse on the clicker itself. Cheap easy fix thank you for your help! Quote
